Question about Canon Pixma iP6000D InkJet Photo Printer
Ink tank absorber full
I have a canon ip6000 printer and an error message keeps popping up that says my ink tank absorber is almost full. Can I solve this myself or is it new printer time (the manual says to take it to a trained technician which will cost more than the printer is worth). Thanks, Sigi Bartel
  • 2,130 Answers
The ink absorber is used to keep the print head nozzles from becoming damaged/clogged. The amount of ink that is absorbed is monitored by the printer itself.
Over time of normal use, you will receive an error when the ink absorber is almost full. You should still be able to print for a while by pressing the "ok" button. This should remove the error.
Once the absorber is full, you will need to have it serviced. You may be able to do the servicing yourself but you will have to know how to reset the counter within the printer, letting it know you have replaced the absorber. You will also have to locate the correct part to replace too. Try calling Canon and ask how much the servicing will be.
If its too expensive, you might try to do it yourself.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Personally, I wouldn't do it myself, I'd inquire w/ Canon about how much it would cost to have it done first...
Posted on Apr 04, 2008
  • 818 Answers
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
    President:
  • 778 Answers
I would use the printer ignoring the message until it no longer functions properly, or begins to leak. As in my humble opinion printers are not worth servicing due to the low cost of replacing them with newer/better technology.
Good luck.
  • Frank  Fernandez
    Frank Fernandez Apr 04, 2008
    Johnychel makes a good point. Look for a reset button or unplugging it for a time should reset the sensors to default and may get rid of the warning.
    Thanks Johnychel
  • Frank  Fernandez
    Ser71, seems to have your printer's functions down to a science and hopefully solves your issue.
    Thank you Ser71.
  • 796 Answers
Have you tried resetting the printer??
SOURCE:
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
5) Select OK
Then turn it OFF and again ON. Check if the error message is still there.
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
MY Pixma IP90v has an error message waste tank full. Can I fix that myself or do I have to take to a repair station?
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
You should send it to service centre
Oct 31, 2009 | Canon PIXMA iP90v InkJet Printer
I too replaced the ink cartridges on my MX700 & had error message
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Please vote if this helps ... Cheers :)
Aug 07, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error message "ink absorber is full", how do I solve this?
replace drum which extracts the extra ink and clean the cart rage heads
Feb 14, 2009 | Canon PIXMA iP1600 Printer
Printer message is: used ink tank is full. Q. where is it...and how do I empty it?
The waste ink tank on Canon printers is the ink absorber which holds the ink used during Print Head Cleaning process. When the error message indicates that it is nearly full, Canon indicates that the printer should be taken to the nearest Canon service center to replace the absorber. There is no supported "do it yourself" replacement for this piece of the printer. As per Canon:
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
If you feel your product might require service, Canon has excellent service options, and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
So, to answer your direct question directly, if the message said "nearly full", you can press OK and continue to print for a short time. If it indicated it is full the printer will not function until Canon services the machine and resets the printer.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Sep 30, 2008 | Canon Office Equipment & Supplies
Waste ink absorber on canon iP 1600
u have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
Apr 01, 2008 | Office Equipment & Supplies
Waste tank absorber is almost full ~ message
I've taken this from my manual.
This error message indicates that the ink absorber is nearly full.
The machine has a built-in ink absorber to hold the ink used
during FINE Cartridge cleaning, for example.
You can continue printing by selecting Continue*1
on the display on your camera.
However, because printing is disabled once
the ink absorber becomes completely full
and until the ink absorber is replaced, you
are recommended to contact a Canon
service representative as early as possible.
*1 To resume printing, you can press
[OK] (MP180) / [Black] or [Color] (MP160) on
the machine instead of selecting [Continue].
Feb 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Maggie B
Feb 10, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma iP6000D InkJet Photo Printer Logo
120 people viewed this question
Clive
Clive
old marine
old marine
Ekse
