Question about Panasonic Cameras
I have a panasonic lumix dmc-fz7. the zoom lens no longers adjust even though it moves when powering on and off. the button used to move the zooms works to move between pictures. the camera has not been dropped or gotten wet
After a bit of research i powered off the camera removed the battery and powered it on. i then recet the it to the factory defaults and it worked fine again.
Posted on Apr 05, 2008
SOURCE:
Is there a long lens for the Panasonic DMC-F27?
Camera is currently equipped with a Leica 12X zoom lens. I would like to be able to take pcs. from a greater distance than this lens permits. Can you recommend a lens that I can attache to the Panasonic DMC-F27 that will enable me to do so? Thank you!!
Apr 14, 2013 | Panasonic Lumix DMC-FZ7 Digital Camera
Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
Sep 19, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Zoom lever stopped working on Panasonic lumix DMC-FZ8
Does it say anything about the lever under zoom levers in your owner's manual?
Nov 07, 2012 | Panasonic Lumix DMC-FZ8 Digital Camera
Where is the lever on the panasonic dmc-fz7 for the zoom
It's around the shutter button. "w"for wide and "t" for telephoto.
Apr 25, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Optical zoom and flash not working on Panasonic DMC-FZ7
None of what you describe sounds good. Any chance you can get your money back?
Dec 08, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
In scene mode its automatucly changing from tab to tab on its own
One of the buttons might be stuck, blocking other input. Try wiggling all of the arrow keys, and see if the tabs stop moving.
May 28, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic dmc-fz5
I posted a solution yesterday on Fixya, but can't find it. Same problem, same camera, solution reached on Feb 10 2009 after a couple days of frustration. I gently wiggled the lens by pushing my fingers one on either side (not the outer ring, but the inner ring, but keep your fingers off the glass part). It moves perhaps a fraction of a millimeter, but it moves. After I did that, the problem went away. It's hard to describe, just a gentle 3 or 4 times push on either side; you may have to change finger positions to get the movement. It apparently only takes this to get the lens back on track. Good luck, it's a great camera. Lee
Oct 29, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
I have a lumix DMC-F27 camera it will no longer zoom. No I not in movie mode.
Do you mean DMC-FZ7?
I own one. Assuming that the camera is working normally, then I know two settings that will cause the zoom to be fixed.
Suggestion No. 1:
If the zoom is fixed at the wide end:
1. Turn the mode dial to "P". Now turn on the camera.
2. Press "MENU SET".
3. Press the up arrow button.
4. Now, a menu item named "CONVERSION" should be highlighted. Press the right arrow button.
5. A sub-menu screen should now pop up, select and set "OFF".
Suggestion No. 2:
If the zoom is fixed at the telephoto end:
1. Follow Suggestion No.1.
Suggestion No. 3:
If none of the above solve the problem, then the lens might have been knocked slightly out of position.
~If the camera has been dropped.
~If the camera has been thumped or banged.
~If while zooming, the lens was obstructed.
The zoom motor also could have died, it costs about $50.00 U.S. at Panasonic.com.
My best advice would be to contact panasonic customer service.
Jul 19, 2008 | Cameras
No zooming
sorry but the dmc-fz7 does not have a zoom ring only a zoom control on the top right.
Apr 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Cameras Logo
215 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
