Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
I have the sony trintron wega 32 hs 500
It blinks 7 times no picture no sound just clicks as if its trying to turn on
when i leave it unplugged for a hr or so and plug back in it sounds like it turns on but goes into standy by mode with 7 blinking
  • 934 Answers
Seven blinks indicates a high voltage shutdown which has exceeded 33,000 volts and immediately sends the unit into a safety shutdown. In this case you would need to check the power supply regulation circuit and horizontal circuit for the failure. It could be as simple as the horizontal output transistor having failed to something more complex or expensive. Need to have it diagnosed for that to find out.
Posted on Apr 05, 2008
My Sony Trintron's LED Light blinks 9 times when I try to turn on the set
  1. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative). If you wish to get more details about the blinking codes to Sony brand TVs, check this link. Pull up older posts there.
Mar 04, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Here's my suggestion , unhook all the external components to the TV and leave the TV unplugged for more than a few minutes (a day/overnight). The next day plug the TV into the wall outlet (not the powerstrip) without anything hooked up to it, and turn it on. See if it comes on. Sometimes unplugging for a few minutes/hours is not long enough for it to reset itself.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a 36" Sony FD Trintron won't turn on and no sound
Have you tried unplugging it from the wall for a couple of minutes, this may reset it.
Jul 26, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My 32'' sony wega blinks 5 times
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Feb 17, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony trintron--red lights
The 2 blinks is a diagnostic code that should indicate the problem circuit. This is unique to each model though. Can you confirm that the model in question here is KV-32FS120?
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega kv-32xbr400
My sony is doing the same thing. but mine blinks 11 times. each time it goes to turn on i hear the clicking then nothing.
Jun 12, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Black screen
If the power supply IC (MX0842) shorts out, it blows the Sony 0.1 ohm fuse resistor. The set will click but have no sound or picture and the LED will blink 5 times. The power supply should be repaired by someone with experience with Sony TV's.
Jun 17, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
