Question about Alpine Air XL-15 Air Purifier
Fan motor changes speeds on its own.
I have noticed that the fan motor sounds like it is changing speed on its own. What would be causing this?
  • 981 Answers
The control component or the control circuit for the fan can be causing the speed variation, or the bearings on the thing can be wearing (or contaminated) with the same result. If you can make a test bench, look (feel with a test pad, really) for drive transistors that get hotter than they should or an inconstant power resistor or shunt.
Posted on Jun 23, 2008
Lasko Tower Fan stopped working but Speed switch has power on all but one cable, How to find the issue?
you should only have power on the black wire into the switch. The white wire feeds straight through. the switch breaks the black and routes it to one of the three outputs for the motor.
Aug 07, 2014 | Lasko 2510 36" Tower Fan with Remote...
Flair living air purificaion system
here are parts for your air purifier, including the motor and other parts you may need in the future.
AirPurifierRepair.
- just click the link
hope that helps, good luck
Jul 31, 2008 | Ecoquest Flair Air Purifier
Ep9r 500 speed button won't work keeps flashing f
The water level sensor fell into the fan. Unplug the humidifier from the wall, stick your hand in between the fan blade and locate the sensor. It is a small black rectangular piece the size of a nickel but rectangular and 3 nickels thick. It also has a 2 inch stem sticking out of that clicks back and forth when you push it. Stick the sensor back into the sensor whole and the flashing f will go away and the humidifier will come on again.
Feb 22, 2014 | Essick Air Whole House Digital Humidifier...
I have an ecoquest flair that the fan won't run.
bad capacitor in the control head..if you run it at full speed, you may be able to run it hardwired(but it becomes a safety issue) may need it replaced..
Jan 18, 2014 | Ecoquest Fresh Air Air Purifier
Fan noise ecoquest 2.1
sounds like the bearings are going bad on the motor check and make sure the fan blades aren't rubbing anything at higher speeds sometime's they will flex
Jul 04, 2012 | Ecoquest Fresh Air Air Purifier
The Fan on my "Fresh
It could be getting clogged up. The lint screen has GOT to be kept clean or the machines fan will pull dust into the machine and it will cake on everything inside, including the fan(will make more sound while running) and can get into the bearings of the fan causing the problems you mention. It may also be a poor electrical connection. If you have ever OILED the motor...you'll have to clean it. It's not meant to have a lot of oil or grease on it.
Jun 10, 2011 | Ecoquest Fresh Air Air Purifier
The fan on my living air purifier doesnt turn anymore. Occasionally when I first turn the fan on, it will "try" to turn but stops almost immediately. do i need to replace the fan motor? Is it something I...
I just bought a used one of these at a sale. Horribly dirty, grimy, rusty, etc. Anyway, similar problem with fan. Clean it off and WD-40 or silicon it. You should be able to see an almost immediate response unless it's another problem. My fan went from a low speed when turned on "High" and from a complete stop on "low" to actually turning on low. Anyway, I laid it on it's front, sprayed some 40 on the back fan bolt (pin, screw, whatever), then used a pen to click the safety so it would turn on with the back off and in less than a minute it was at full speed. Good luck!
Sep 22, 2010 | Ecoquest Living Air Classic Air Purifier
No Medium Fan Speed
sounds like ur medium speed has gone out
Feb 20, 2010 | Air Purifiers
I cannot adjust the fan speed. There is 1 spot on
If there is only one spot on the fan control dial that turns on the fan, it seems that the fan control pot has failed and needs to be replaced. You can call the company and order one and it should fix your problem 800 989 2299.
Jan 03, 2010 | Alpine Air XL-15 Air Purifier
Clean fan area
NOTE:It is easier to remove the motor when the upper housing is still sitting on top of the lower housing unit.
  1. Turn the power off by unplugging the unit.
  2. Next to the speed directions buttons there are thumb tabs. Press the thumb tabs so that they pop up and unlock the upper housing flaps. a tumb tab on
  3. The four flaps should then drop down like the peddles of a flower.
  4. Grab the center of the motor and lift straight up, be careful when pulling the power chord.
  5. The motor, fan and gear assembly should not be seperated from the rest of the unit.
This will let you clean with vinegar and water.
Great product. Germany design at its best
Oct 30, 2008 | Venta - Airwasher LW44 Air Purifier
Alpine Air XL-15 Air Purifier Logo
102 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
