Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Isony tv wega 32 hs500
It blinks 7 times what do i do am i gonna need a repair person or is this something i can fix myself
    Scholar:
  • 131 Answers
Hi you will need a repair man. I have a tv repair center. We see alot of these tvs when it blinks it has a few things it could be here are the lists and prices for no one can cant take advantage of you.
1 screen voltage adjustment simple fix in expesive fix just adjustment
2 there are two transistors and a fuse that go bad in power supply.estimate is 120.00
3 flyback and horz output 225.00
thanks DOCTOR VIDEO ask servicer on phone his cost on these before you bring it in. good luck
Posted on Apr 27, 2008
I have a sonyTrinitron KV32HS510 .It will not turn on ...it sounds like it will but then I get a blinking code.Most of the time its 6 blinks .Sometimes its 7 blinks.Is it worth fixing and what should I...
six blinks mean that the tv has a problem in the horizontal circuit.have a tech repair your tv.the problem is in the following component. C 515 AND 516 and IC 206 which is the jungle IC.since you say it also blinks 7 times then there is a high voltage shut down which exceed 33k chech the power supply regulation and of course the horizontal circuits.a cost for this job is around $100.00 Good luck. if you dont want to invest in repair then i advise you buy a new tv.good luck.
Sep 14, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV36 HS500 7 BLINK PROBLEM
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Hope that helps.
Nov 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My sony wega 32hs420 timer light is blinking 7 times stops then blinks 7 times and so on. do i need a repair man to come look at it?
Yes,this problems must have parts change.Repair and parts should be under $250 more than that not worth it to repair old CRT tube tv.High Voltage parts are dead must get it replaced.
Jan 23, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My 32'' sony wega blinks 5 times
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Feb 17, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
7 flashes on my 34HS420 Sony TV
7 blinks indicates problem of Horizontal deflection failure. Possible cause can be Horizontal Out Transistor and / or Fly-back Transformer shortage.
If you have TV repair experience and electronics knowledge background, let me know to guide you more OR take TV to local TV repair shop for proper fix.
Jan 06, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Oct 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have the sony trintron wega 32 hs 500
Seven blinks indicates a high voltage shutdown which has exceeded 33,000 volts and immediately sends the unit into a safety shutdown. In this case you would need to check the power supply regulation circuit and horizontal circuit for the failure. It could be as simple as the horizontal output transistor having failed to something more complex or expensive. Need to have it diagnosed for that to find out.
Bill
Apr 04, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
36 inch sony wega trinitron
I had the same issue earlier this week. 4 year old sony trinitron wega 32 in. I was told by Sony to call technician to repair and have called tech....could be anywhere from $200-$300 repair. I did research the blinks (google "sony blinking codes" to find out what each means) Ours was 6-7 blinks which meant power surge to tv. I advised to Sony that i saw many of the same issues with many of the newer tv's and suggested a recall issue--they denied and where no help.
I will buy a new tv now--definitly not a Sony.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony TV
Blinking what - how many times before it pauses and then blinks the next set?? Sonys have an error code of blinking to help isolate the problem... (count the number of times it blinks before pausing and let me know).
Bill
Dec 12, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
32 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
