Question about Samsung HCL473W 47" Rear Projection Television
No Raster, but sound works
I've lost picture, but the sound is still there. The week before, it would come on after a few minutes, fading in overzoomed and unaligned. This would clear up before my eyes like an old TV warming up. Now black screen and all the listening you can stand. Any suggestions?
  • derek_opie Apr 04, 2008
    No, no visuals of any sort now, but everything else functions because I can hear the different sources if I switch inputs. I've got myself a service manual, though it seems geared toward someone with intimate knowledge of samsung products (go figure). Armed with this and your advice I'll dive inside when I get back into town. I guessed it would be something common to the three guns.
  • derek_opie May 08, 2008
    Well, I'm back to look at my TV and I can't find the driver you recommend checking, even with the service manual. It leaves out a few things I like to see like a board layout. It does have a flowchart for troubleshooting my specific problem, but uses general terms meant for someone who is familiar with TV servicing.
  • Samsung Master
  • 8,617 Answers
Sounds like vertical deflection has caused the tubes to go into blanking. Do you still have on screen displays? Try resoldering the vertical output IC. If that doesnt help the vertical output may be defective.
Posted on Apr 04, 2008
  • Sonny Berry
    Sonny Berry Apr 04, 2008
    yes if vertical deflection stops all 3 CRTs will shutdown for protective reasons.
SOURCE:
Works fine, clear picture. Picture fades, then gone. Turn it off, wait a few minutes, turn it back on and presto, fine again. What's wrong?
You have a problem with a bd or power supply is heating up and causing you to lost the picture need to have it serviced
Dec 16, 2015 | RCA HD61W66 61" Projection HDTV
Hi I have A Marshall JCM 2000 TSL122. It starts out having full sound then all of a sudden no sound then after a few seconds, minutes or several minutes sound is back!
I suspect it's your input jack if it stops working immediately and comes back immediatly rather than fading in and out. Give it and any other jacks a good cleaning and see if it helps.
Jul 27, 2015 | Marshall Music
Picture fades to black
Find the vertical IC and check for very small cracks on the solder joints of its pins and resolder (approx. 10 Pins). Also check in the same area for a 1 micro farad at 50 vdc capacitor that goes bad and replace it.
Dec 18, 2013 | Toshiba CX32F60 32" TV
Hitachi 51F710E has no sound
The audio portion of the main board is failing. You can get a replacement here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 07, 2017 | Hitachi 51F710 Rear Projection Television
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
KP-51HW40
sounds like the tuner may be going out on the set.
Aug 10, 2008 | Sony KP-51HW40 51" Rear Projection...
No picture
Good Day;
No video, has raster and sound, check I012, 3.3 Volt reg.
Good Luck, big IRISH.
Jul 26, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Panasonic PT-47WX49E
The only thing I can think of that would make the picture fade to black is a loose solder joint on the filament supply. Each of the 3 picture tubes has a filament and if the 6.3 volt supply to those filaments is suddenly lost, the picture fades to black as the filaments cool down. An experienced tech can find and correct this for you quite easily.
Sep 10, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Samsung HCL473W 47" Rear Projection Television Logo
181 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
