Question about IBM ThinkPad R40 2722 Notebook
Whirring Sound Can't quite figure out if the hard drive is dying or what. It's not the fan, as I can hear it come on and off periodically, but the sound is coming from the same space (upper left side) of my laptop. Suggestions? Advice?
  • gruurly Apr 04, 2008
    Thanks everyone. I should have added it already is sitting on a cooling pad.
    Interestingly, the sound has disappeared now, and everything seems fine. I'll blow out the fan and oil the bearings in case that is the issue, and look at heat and speed programs to see if that's the issue too.
    This is just a temp laptop (my old one) while my new one gets fixed while still under warranty (it had LCD issues).
    Sergeant:
  • 202 Answers
Hello gruurly
There are only two possibilities as there are only two device types inside your laptop that have moving parts; fan(s) and hard disk(s). The sound you described is usually a fan.
Normally, when a fan dies, it does so slowly and painfully over a period of time. It'll begin w/ the whirring - some times w/ the sound oscillating up in down - indicating the fan is unbalanced or for some other reason varying in RPMs.
When the noise stops - that's not necessarily a good sign. It could mean that the fan bearings have frozen completely and it is not spinning at all any more.
It is quite possible that there is more than one fan inside your laptop so, while one sounds as though it is working fine, another could be on its last legs.
This is one of those cases where a $10 or $20 part can kill a $900+ system. Computers' electronic components are extremely sensitive to heat. Keeping that heat at a minimum is particularly critical in laptops because of the closed space and limited room for air circulation.
I recommend you check IBM/Lenova's web site for a Service Manual on your laptop. Find out how to open it to get at the fan(s) and what is required to replace one. While you're at it, get a can of compressed air and blow out all the dust and dirt inside your laptop. Get a tin of sewing machine oil, too and place a drop into the bearings cylinder of any remaining fans (you may have to lift the fan label to do this.)
In the interim, you can purchase an laptop cooling device (or "pad"). This is a device w/ built-in fans that you sit your laptop on top of. Some of them will plug right into one or two of your USB ports to power the fans.
You can find some examples of them HERE on Newegg.com (a great resource for purchasing electronic devices online. Their prices are very competitive and their customer service is excellent).
If you need assistance finding your laptop's service manual, just let us know, we'll help you w/ that.
Please, let us know if this response was helpful for you or, of course, if you have more questions, etc. on this topic.
Thank you
BJ
Posted on Apr 04, 2008
  • B Joan Rapier
    B Joan Rapier Apr 04, 2008
    You're welcome, of course.
    That's great you're already using a cooling pad.
    That's pretty normal (the sound coming and going in the beginning). When fans start to fail, the problem starts out being very intermittent then gets worse and worse (w/ respect to sound) and finally stops making the sound all together (usually because the bearings have frozen up completely).
    Be sure that, when you oil the bearings, that you replace the sticker (covering them) securely. If you have to, tape or glue it back down. You don't want the bearings exposed (they'd get all clogged up w/ dirt and dust in no time).
    The sewing machine oil is an old trick. It comes in real handy for prolonging the life of fans - particularly those whose form factors can't be found any more because they're obsolete.
    Just let us know if you have any more questions, etc. We're glad to help.
    President:
  • 778 Answers
It's probably your Hard Drive (as you suspect) , as other than the fan(s) and optical drive(s) the only other moving part would be the Hard Drive. You may want to start backing up your data and shopping for a larger, faster HD, if it is failing. Due to the heat issues with laptops it's pretty common that Hard Drives lose their lubrication and begin wearing out their bushings/bearings (which would make noises). Just make sure you have eliminated the other possibilities. You can find software to monitor the temperature and speed of your hard drive to help isolate it as the problem also.
Toshiba MK1059GSM sudden noise?
First backup all your data asap. Noises of this type are a sign of a failing drive.
Then run the extended test... http://gsmartcontrol.berlios.de/home/index.php/en/Home
You should be able to replace the drive with in the one year warranty period.
Sep 12, 2012 | Toshiba (MK1059GSM) 1 TB Hard Drive
I have a FD 500GB hard drive, and have a problem in recognizing the hard drive with my media player as well as computer..it was working fine couple of days back since 2 years..suddenly this problem came...
Unfortunately it sounds like it may have crashed. Try placing it on its side and trying again. If it does the same thing the best you may be able to do is find a professional that can get the information off and put on another drive.
May 21, 2011 | Fantom Titanium II (TFD500C16) 500 GB USB...
I have a Lacie 1TB Big Disk Extreme. It has recently developed a loud regular whirring noise, that goes on and off every few seconds. What should I do? Thanks! Adrian
The irregular clicking or chunking sound usually indicates that your hard drive is suffering from physical damage. immediately backup your data, your hard disk will die soon.
This problem can be caused by the following:
  • Head Crash
  • Bad Sectors
  • Mechanical Faults
If your hard disk is under warranty then you contact your manufacturer.
Hard disk drive occasionally produces a whirring sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the sectors where the data is stored. It is important to distinguish the whirling sound from the clicking sound. This whirring sound can be reduced by periodically defragmenting your hard drive. Defragmenting reorganizes the scattered data on the hard drive to make files and programs run faster. It relocates the commonly accessed files to the beginning of the hard disk where data can load at a faster rate.
Apr 08, 2011 | LaCie Big Disk External USB 2.0 1TB Hard...
Loud whirring sound
Three things spin in a computer; the hard drive, the optical drive and the fan. If there are no disks in the optical drive (open it[them]), listen close, if the noise is from the front--- think hard drive, if it is in the back--- think fan. If it is in the front, back up all your data NOW. If it is in the back you need to replace the fan, (or perhaps just clean it) before the heat fries your motherboard.
May 12, 2010 | Dell Inspiron 530s Desktop Computer...
The 622 just stops playing, then you hear a
Sounds like a hard drive failure. Contact Dish Network for warranty/repair info.
Dec 15, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Our DVR is making whirring noises like it is trying to load a disc and we have no tv in the main room but the office has signal wtf?
Haha Dont worry dude its just your hard drive or your fan. Your DVR also cuts on around 3-4 a.m in the morning too download software so thats cool. If this just started too happend it could be your hard drive or your fan going out but if its only for a a set period of time its your fan trying too cool down your hard drive. But!!! If you hear it all the time and it is really loud than most likely you will have too get it replaced. Here are a couple things too try.
  1. Unplug the reciver for an hour
  2. If in a surge protector remove it and plug it directly
If you need anymore help let me know
Nov 21, 2009 | DISH Network Televison & Video
Gateway laptop - whirring, buzzing sound
if it's a continuous whirring sound it is most likely the cooling fan. this is normal. as the computer gets older this will get noticably louder as the fan has to run faster to prevent overheating.
Aug 14, 2009 | Gateway Computers & Internet
Whirring sound after long drives 2006 Chrysler Town & Country
It is your power steering pump. The solution is to replace the P/S fluid resevoir and fill or flush the system.
Mar 07, 2009 | 2006 Chrysler Town & Country
Louder whirring noise when turning on computer
trumpjd,
Usually on startup the fans work a little harder then slow down. On newer computers they still have noticable fan noise. Most of what ou hear while the machine is running after start up is the power supply fan. When it starts to go bad you'll hear it all the time.
randy320sgi
Jan 09, 2009 | E-Machines eMachines Desktop PC
IBM ThinkPad R40 2722 Notebook Logo
198 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
