Question about Yamaha RX-V630 Receiver
Yamaha RX-V630 Doesn't power on!
The receiver doesn't turn on when you push the power button. It just clicks and the click sounds like it's coming from a relay but I checked the relay and it is working fine nothing wrong with it. Any suggestions on what else it could be??
  • 3 more comments
  • toets Apr 07, 2008
    yamaha rx v630 doesn t power on
  • Anonymous May 19, 2008
    I have EXACTLY the same problem.  Clicks when you try to power on.  helP!
  • Anonymous May 25, 2008
    The RX-V630 doesn't turn on when you push the power button
    it just clicks. Any suggestions ?
  • sfine306 Jul 27, 2008
    Same problem with mine as well.  Press the power button. get the click, but then nothing comes on.  Wondering if this is a widespread issue, because my receiver shop wants $350 to send it in to be fixed.
  • Anonymous Dec 15, 2008
    i have the exact same problem
    Genius:
  • Yamaha Master
  • 1,550 Answers
Los receivers traen un transformador este trae un fusible termico quizas este dañado por eso no enciende.O los amplificadores de audio estan dañados checa desoldandolos.
Posted on Apr 04, 2008
I have the same problem.
Posted on Sep 04, 2008
How to connect a turntable to Yamaha Rx-v630
If your turn table has a ground wire with the R and L wires then you can not connect it to this receiver. Unless you have a switch on the turn table that chooses between internal or external amp. If you have the switch, pick external amp and then run your R and L into your TV/CD input. Good luck to you.
Jun 06, 2016 | Yamaha RX-V630 Receiver
How do I hook up an equalizer to my Yamaha RX-V630 Receiver ?
you hook it up through your tape monator just like you were hooking a tape deck up if you have a tape deck pluged in there you should be able to plug it in to the back of equalizer the same way
Sep 08, 2014 | Yamaha RX-V630 Receiver
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
YAMAHA RX-V630 WON'T POWER ON NO CLICKS
If the unit is like the Rx-570 , the display bulbs have quit.
Theyre 14 volt lamps about 0.1 wide x 0.250 long (white wire leads)
Located in the plastic shroud behind the display
Mar 23, 2009 | Audio Players & Recorders
Yamaha av receiver rx-359
go to best buy and buy a new recever
Jan 12, 2008 | Yamaha HTR-5560 Receiver
Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Jun 05, 2007 | Yamaha RX-V630 Receiver
Yahama receiver Rx-630 not working
The problem might be caused by two major circumstances. 1)Touching wires 2)Overheating. I suggest you unplug all wires connected to the amp then turn on the amp. If it gets turned on then we know that the problem is that you have touching wires. If there is a short circuit somewhere, get rid of it. The ventilation is another important issue that you have to pay attention. It simply causes overheating.
Yamaha RX-V630 Receiver Logo
729 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
