Question about Cell Phones
Phone problem :(
My phone resets whenever i:
try the camera
use the games
and use blootooth
    President:
  • 778 Answers
You can try removing your battery and cleaning the contacts on the phone and battery by rubbing them with a pink pencil eraser, as the problem may be intermittent/poor contact there due to oxidation and when tasking/loading the power supply could cause the re boot, it's worth a try.
Posted on Apr 04, 2008
How do i alter the time on my motorola l6 mobile phone
SOURCE:
The blootooth does not connect by itself
The bluetooth is supposed to disconnect with the power being turn off and, being out of range. You can setup your phone to automatically connect instead of being asked to connect. That selection is made from your phone.
Aug 10, 2012 | Kenwood KDC-BT752HD
I have a VDO Dayton CD 2737B Stereo Head unit and I need a replacement Blootooth microphone. Can anyone help please?
It's not microphone ! I had same probelm, it depends on the phone you are using. Try with different phone model. For example, with Nokia N95 works perfectly (talk, audio, even voice dialing), with Nokia 6220c or N85 sucks...
Almost half of the phones that I tried had some issue, very similar to yours. Usually, you can hear everithing but person you talking to hears just loud noise
May 25, 2012 | GPS
My sony ericsson has no power,when i open at the games
Not really understanding this question, but if you mean whenever you open games your phone cuts off then here is what you need to do....
1) Try reseting your phone. cut it off, pull out battery, put it back in and cut it on.
2) Reset factory settings.
3) If all fails get a new phone. Ive read this phone is prone to software problems.
Mar 01, 2011 | Sony Ericsson K530i Cellular Phone
Sony ericsson k530i camera is not working,whenever i switch on the camera button it shows nothing.
hi
reset the phone and try it.. For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the pass code as 1234 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and photos.. this will fix your problem. if still having same problem means contact your service provider..
thank you
Dec 22, 2010 | Cell Phones
Whenever i try to access the games or applications folder an "operation failed" message is displayed and they wont open and i am afraid of performing a master reset so as not to lose the phone's original...
Hi what causes it is that those particular games are corrupted and will need to be deleted before it affects the rest of the games.or you might end resetting the phone. Be fast about it.
Good luck.
Aug 24, 2010 | Sony Ericsson K850i Mobile Phone
Camera won't work
Have to reset your camera settings.service care can reset with ease.
Jul 26, 2009 | Samsung Blast Cellular Phone
Sony ericson keep on crashing halfway through master reset
This phone support java compatible softwares, games etc.... it seems that you have installed a games which is not compatible with sony erricsson software. I would suggest you to remove the games which you have installed on your phone. Install only java supported games on your phone. After deleting if still your phone crashes update your phones software. This will resolve your issue
Apr 09, 2009 | Sony Ericsson K850i Mobile Phone
Hello
do this restore factory settings...
Apr 16, 2008 | Nokia N95 Cellular Phone
Razr V3 Camera
most of the time you will need to replace the camera on the phone. First try to do a master reset and a master clear on your phone (warning master clear will erase EVERYTHING on the phone a reset just takes the settings back to when the phone was bought) this is in your settings menu under initial setup and is towards the bottom. if that doesn't solve the problem you can buy a new camera at cnn.cn (use the 19.50 shipping or else it takes forever)
Aug 06, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Cell Phones Logo
56 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
