Could use more info. but, is it just going in to sleep mode ?..check your power settings under Display properties, Screen saver, Power.
Do you hear any Beep codes at startup ?. .does it shut off after maybe logging on to windows ?. . Check to see if the Fan runs, it may be over-heating and shuts down to prevent thermal damage to the CPU. if your fan is not running, DO not start it up till u replace the fan.
good luck,
djEnigma
Comments:
Apr 05, 2008
- What do you mean Unplug and hold for 30 sec ? .. maybe the battery is fully dead. If you can log in then, check the sleep settings under Display properties, Screen saver, Power.
Please suggest the best external hard drive 320GB.. Which one should I prefer? Seagate or transcend...
(More)
Please suggest the best external hard drive 320GB.. Which one should I prefer? Seagate or transcend ?
What is the best NAS for about $300 (+, - $100)? I was looking at...
(More)
What is the best NAS for about $300 (+, - $100)? I was looking at http://www.bhphotovideo.com/c/product/629822-REG/Buffalo_LS_XH2_0TL_2TB_LinkStation_Pro_LS_XHL.html,I need 2 TB of space, about 40 MegaBytesPerSecond, bittorrent, dlna , and web (configuration) access.
