Home | Projection Televisions | 42 inch flat screen tv
Problem for Projection Televisions
Generic problem for all Projection Televisions
By bebef227mare on Apr 04, 2008
42 inch flat screen tv always shuts off
Same Problem
Jan 01, 2009
-   the screen is blank, if I hit live tv and it comes on, then I press the menu, and then it goes off. When turned on it takes a few seconds to come on, and when turned off it takes a couple seconds to go off. It started with it not going off , and I had to power button a couple times before it would go off. It puts out a lot of heat.-   stevenjh1
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
TV wont turn on. When I press the power button, the Timer/Stand By light flashes 11 times then shuts... (More)
Answer
KP 41T15 Sony Projection set. The timer light flases constantly . As you power up the tv..you can... (More)
Answer
Vertical line in middle of screen. Half screen is ok. The right half shows color washou All... (More)
Answer
I have two Philips PTV. Model#50P8341A when powered up...The power button will flash 5 times pause,... (More)
Answer
where on the tv for the Z62DC1D tv do I go to change a lighbulb
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Projection Televisions:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
