Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
C4180 printer I keeping getting the message to remove and check cartridge on right. I've remove, replaced and reset the printer. All it does is slam to the right and refuse to work.
  • Anonymous Mar 21, 2014
    there's a problem always shown that"remove and check right cartridge"
    Problem Solver:
  • 12 Answers
Hi ,
This product clearly needs a servicing as far as my experience goes . Still we shall go ahead and try to reach the solution or else this definitely needs servicing. I shall explain why -
1. check cartridge on right : if you have replaced the black cartridge and have been using the original cartridges then its an issue with the print heads. The black print head needs to be replaced by the local service centre . There is a blockage in the nozzles of the print cartridge that passes out the ink.
2. slam to the right : if i am not wrong this is the carriage you are referring to. Do the following steps (though i presume you might have done it if you have reset the printer)-
a. pull out the power cable
b. open the cartridge door and hold the carriage with your hand and move it manually 4-5 times left to right with as much speed as possible....there should be no obstruction on the way it moves.....if there is a pin / peice of paper / any obstruction - remove it if you can. The carriage could also slam if the pin of its movement has gone loose and it keeps on slamming uncontrolably. This seriously needs a servicing from the local service centre.
Posted on Apr 09, 2008
SOURCE:
Print cartridge in right stall not supported for hp 2410
Print cartridge is a knock off. Cartridges have printed circuits in them that the printer can recognize as being the original replacement. This is to keep people from using other products in their printer, which I think is foul, since you paid for the printer and it technically belongs to you. Sometime HP will make cartridges with faulty circuits that the printer will not recognize.. If that is the case call them and demand a new ink cartridge.
Dec 12, 2017 | HP PhotoSmart C4180 All-in-One Color...
My c4180 printer says Ink cartridge problem. Remove and check colour cartridge. Cant get message to go away. I use original Hp ink cartridges
If the color cartridge contacts are clean and there is stil ink in the cartridge.
What you could try is to remove both ink cartridges.
Close cover and turn off printer and unplug the printer.
Wait at least 15 minutes for the printer to reset to clear memory.
Plug the printer back in and turn on and install the ink cartridges.
If you cartridge is not empty and has not expired.
You may call HP and ask for a free replacement.
Jan 09, 2011 | HP PhotoSmart C4180 All-in-One Color...
My hp C4180 screen keeps displaying :"remove and check cartridge on right". When I do and place back into the slot it repeats the message.
check the pins as they may be dirty. the pins are the ones of the carraige of the printer. remove the heads and wipe it clean with a kleenex. use distilled drinking water if you need to, not alcohol or any other water. if it still persist check with another cartridge, the cartridge may need replacement.
Jun 19, 2010 | HP PhotoSmart C4180 All-in-One Color...
Hp Photosmart c4180 - Keeps saying "remove cartridge on the right" I have removed and replaced with new cartridge however the problem persists please help.
Pick up the printer. Carry it outside. Lift the lid on your trash can. Gently place printer in trash can. Close lid. Wait until garbage day. Open trash can lid........problem solved. Reminder.. never buy HP again.
May 20, 2010 | HP PhotoSmart C4180 All-in-One Color...
Printer keeps saying remove cartridge on the right
i have this problem to.. will try to reset it and resend
Mar 29, 2010 | HP PhotoSmart C4180 All-in-One Color...
Incorrect Cartridge Print cartridge in right stall not supported?
I changed the cartridge and it now works. I resent this though because it had been merrily printing before it decided it would stop and I have had to waste a three quarters full cartridge! I just hope the new one does not go the same way
Apr 08, 2009 | HP PhotoSmart C4180 All-in-One Color...
Printer Cartridges won't align C4180 printer
Printer keeps trying to perform an alignment after installing a new black ink cartridge fix:
1. Unplug USB
2. Turn printer off
3. Wait 10 seconds
4. Remove paper from paper tray so printer has no paper to print on
5. Turn printer on
6. Printer messages to insert paper in paper tray
7. Press and hold “Setup” and “ Cancel” buttons and press “OK”
8. Should be good until next black ink cartridge change.
Nov 28, 2008 | HP PhotoSmart C4180 All-in-One Color...
Repeated error message
Very Simple, Probably...
Just remove the cartridge and see if the metal spring clip has broken away from the right wall. If it has, inspect the gold colored circuit board at the back of the cartridge bay...there is probably a hole or dent where the clip slammed into it.
If you have these symptoms, go to HP, and go to the chat support window, describe your problem, and they will send you a replacement printer.
It's exactly what I did.
Jan 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
416 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
