Question about Amana DLW330RA Top Load Washer
Loud whirring sound
During the spin cycle there is a loud whirring sound, it is spinning, however the water does not completely drain out.... if you shake the basket, you can hear the water......
could there be something stuck in the filter/pump and/or out of balance/spring broke????
  • cbcaj Apr 05, 2008
    Thanks for the info.....
    I removed a substantial amount of water from the discharge line using a shop vac.
    I opened the front of the machine, the black rubber part of the discharge hose was
    twisted and flat, it had come off of the plastic bracket... It has lost
    it's shape and remains flimsy and twisted even after removing and
    repositioning it.
    The spin cycle completes but there is water still left in the machine...also when the lid is lifted the tub stops abruptly.... could this be the "idler or tension pulley" that is the problem?.... the belt is in tact and appears to be in good shape.
    President:
  • Amana Master
  • 2,651 Answers
No problem withthe water they sometimes use a water ring for balance, or you may be hearing water reaming in the pump and hose areaa, its always there. as far as not spinning completly you may need to replace the belt or the idler(tension pulley), two 5/16 screw along the very bottom of unit will gai you access to see inside the machine
Posted on Apr 05, 2008
  • Ron Coons
    Ron Coons Apr 06, 2008
    sonds as if your not draining quick enough, is your standpipe clear,??? stopping abruptly is the brake kicking in def normal for this machine, i would look into the tension spring, pulley, blet oi be the issue, ive seen where the pulley has slipped off its mount adn the belt is holding tension between the pulley post.
SOURCE:
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
Tub filled with water, Lr code
To pump out the excess tub water while failing to complete spin cycle;
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
This process is documented in the Service Manual. I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
If I could ask you to do a little troubleshooting;
It sounds like the wash/agitate cycle completes and you enter into the spin cycle of the selected wash cycle is that correct. When the wash cycle fails does the Cycle Status LED indicate that the washer is in the Spin cycle?
With a empty wash basket no wash load in the basket and you start a Spin Only cycle will the Spin Only cycle complete?
If the washer will start the cycle do you hear and loud Spin Only cycle noise such as metal against metal grinding noise?
With the washer off and no clothes in the wash basket can you open the lid then Spin the wash basket as fast as you can in the CCW direction the only direction. The wash basket should spin CCW several rotations and coast down to a smooth stop dose it?
I’m checking for Outer Tub increased bearing resistance…..Rich
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jun 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II spin cycle not functioning correctly
It sound like the basket is out of balance. When it spins open the lid and see if the basket is moving side to side and back to back. If so look under the deck and see if there is springs or rubber ties attached to the basket.
Jan 19, 2009 | Whirlpool LSQ9665JT
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
May 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Water does not drain, strange noise while in spin cycle
sounds like something is stuck in your drain system. Most likely just in front or even in the pump
Please check this
Apr 22, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Amana DLW330RA Top Load Washer Logo
269 people viewed this question
Top Amana Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
