Question about Asrock K7S41GX Motherboard
Motherboard now replaced
Hi Mike, thanks for your previous assistance. I have now put a new motherboard, fan and heat sink in, together with a new PSU with a case fan, (to be on the safe side). However, I am still getting nothing on screen. The CPU is a AMD Athlon XP 2500+. When I felt the heat sink with the PC running it was barely luke warm, (I believe it should be pretty hot!), so I disconnected the fan to try and force the COP to be activated - nothing except a slight humming from the power on button. When I took the CPU out originally I noticed that there was a scorch mark underneath, (is this normal?). Anway I have ordered a refurbed CPU of the same spec to see where we go from here. I have set the FSB on the mobo to the correct setting (333 mhz). I have re-checked all of the wiring and it is as per the board diagram. The board was installed with an anti-static wrist strap so I know it should be OK. I have two memory sticks and have tried them independantly on the basis that both would have failed at the same time. The VGA card has not been instald yet as I wanted to try the on-board graphics first. I have also re-set the CMOS after removing the power lead and PnP items. Thanks once again.
  • Eagleboy Apr 05, 2008
    Thanks Mike, I have now installed the new CPU and..... SUCCESS! The hard drive wouldn't boot so I put the new hard drive in and re-installed XP. However, it would only recognise 128GB of the 160GB available. After installing SP2 and Partition It I was able to merge the unallocated partition. Thanks for all your advice it was much appreciated.
    President:
  • 2,351 Answers
Hi Eagleboy, the odds of two boards having the same problem are something way out there. The only constant is your case, memory & hard drive.
To answer your first question about the CPU being luke warm is (very good)! That is what it should be. Please plug the fan back in. (You said -" When I took the CPU out originally I noticed that there was a scorch mark underneath, (is this normal?)". Yes & No. Every CPU should have either thermal grease or a thermal sticker which helps pull the heat from the processor to the heatsink. Over time if the processor was running hot the thermal sticker most likely withered away which left a scorch mark on the heatsink. A thermal sticker (which is much less messy), is not as good as thermal grease. (My opinion).
Since this is a new board, now would be the perfect time to download the hard drive's utility tools. Find the name of your hard drive & S/N, go to the Mfg's web site & download their setup tools. If you have two hard drives unplug the data cable for the second drive. Create a bootable floppy disk or bootable CD & run the Mfg's diagnoses on the drive. Think back, you mentioned you had formatted your hard drive & the system ran fine. (For awhile).
This seems to be the single connection between the two boards.
It's always suggested to do a fresh install of windows when a new motherboard is installed. So check your hard drive Eagleboy, check it twice & setup once.
Below is the link for your new board. Bookmark it.
http://www.asrock.com/mb/overview.asp?Model=K7S41GX
Good Luck! Check that drive.
Have more questions, feel free to ask.
Mike
Posted on Apr 05, 2008
SOURCE:
My motherboard keeps on overheating @ 70C and over plz what must i do?
Hello and Welcome to FixYa!
If the overheating is not due to hardware issue, faulty components, you can control the temperature by using Heat sinks and Temperature controlling fans, and by regulating a proper Air flow to the unit. For this, you can also use Cooler Master casing specially designed for high end purposes, or can use any such available brand to control the temperature...
Concerned.
Jun 28, 2011 | ASUS P5KPL-AM SE Motherboard
Hi, I am having an issue where upon waking my computer from standby mode (S3), there is no display and fan speeds become irritably loud and fast. I have no choice but to turn off the power from the back of...
if you did not used heat sink paste between the heat sink and the cpu unit, that, will be you problem initially
the paste is used to exclude any air and gaps between the cpu back and the heat sink and makes a perfect heat transfer medium
cpu units will hit critical temps within seconds if the heat is not being transfered correctly
Mar 07, 2017 | ASUS M4A78T-E Motherboard and AMD Phenom...
Sir, I have a Dell optiplex GX110. At the motherboard there is a long brown slot in which a board of 4 expansion slots has been pluged. The first problem was that I had removed the heat sink from the...
When you inserted a test probe into the slot and you saw a spark, then you have short circuit a component on the motherboard and have done a major damage to the motherboard.
You need a new motherboard, most desktop cases have standard mounting holes, you may be able to purchase a motherboard from other manufacturer to fit in the Dell.
Oct 09, 2010 | Dell Optiplex GX110 (2909T) Motherboard
Problems with Abit NF-M2S Motherboard?
hi there..
i also have the same mobo like yours. i also thinking to upgrade my old processor with better one..
made some quick research.. i would say the mobo unable to support the new processor. checked the BIOS update n CPU support list in Abit's site..
didn't show X4 processor is supported :(
Jan 15, 2010 | Abit NF-M2S Motherboard
Algerian-47
you could try removing power lead then remove battery from m/b for 5 mins this will reset bios back to maufacturers settings then replace battery and power then try boot up if no luck then change motherboard
Jul 01, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Buzzer sound from motherboard spkr
Hi kuldeep11203, your Intel D101GGC board uses the Award bios. http://www.bioscentral.com/beepcodes/awardbeep.htm
Though the descriptions vary, I suggest you check your CPU heat-sink & fan assembly. Clean assembly from excessive dust build up. Remove CPU fan if possible & clean the heat-sink. Check the CPU fan, it may be turning too slowly & may need to be replaced. The average CPU fan runs between 2000 Rpm & 3000Rpm. Blow out your power supply with canned air. Disconnect & than re-connect the Main power connector (2x12) on the board. Item No# K, found on page 11 in your manual. Try these first. See if the buzz sound stops after a good cleaning.
If not replace the Heat-sink assemble with a new one. Check this link for a new assembly for LGA775 socket;
http://www.google.com/search?hl=en&q=heatsink+and+fan+for+LGA775+socket&btnG=Google+Search&aq=f&oq=heatsink+and+fan+for+
Good luck kuldeep11203!
Mike
Nov 21, 2008 | Intel D101GGC Motherboard
Pentium D problem
Hi oilian,
Be glad it did shut down. If it didn't, your new CPU could haveover heated. There are a few reasons for a CPU to over heat.
1.) There is no thermal grease or too little on the heat-sink assembly.
2.) The old thermal grease was not removed or the old thermal tape was not removed.
3.) The heat-sink assembly was not cleaned completely with alcohol before applying new thermal grease.
4.) The CPU fan is running too slowly.
5.) The heat-sink fins are possibly filled with dust build-up & the CPU fan can not cool the heat-sink assembly. Boot to the bios & go to Hardware Monitor. There you can check voltage, CPU fan speed, CPU temp & other bios monitored settings.
Good luck oilian!
Mike
Oct 01, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
Constant Rebooting and System Error Messages
I suspect you could have a heat sink fan not working remove side of case and when you turn computer on check fans heat sink and video card are working
With computer OFF
remove heat sink fan and check that the heat sink is not clogged up with fluff and dirt.
I regularly clean both fan and heat sink every 2 months also check the fan in power unit and blow it out
Aug 16, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
AM2NF6G-VSTA: Contantly system powering off suddenly because of overheat
disconnect everything from M/board except for memory and video
this means hard drives cd dvd etc only leave memory and video connected
check your cpu heat sink for dust and fluff clogging it
then try to boot when you do check cpu fan working
If it still fails to start your motherboard is probably 90% buggered and you need a new one sorry for the news
Aug 05, 2008 | Asrock AM2NF6G-VSTA Motherboard
Dell motherboard {GX 270} over heating.
Hi
It seems the system is "dying" or already "dead". The initial heat issues suggests a faulty Processor (PRC) Fan. Faulty Power Supply Unit (PSU) Fan can have same effect.
Open the Base unit; disconnect everything (incluiding Keyboard, mouse, network) power-up and check that PRC and PSU fans are working.
Also check the QUAD Pack Diagnostic LEDs and compare the sequence with http://support.dell.com/support/edocs/systems/opgx270/en/ug/solve.htm#1235408.
This will help with identifying the cause. Try the Dell Suggested Resolution.
Reply if further help is needed
Regards
Mike
Mar 30, 2008 | Dell (4T274-DE) Motherboard
Asrock K7S41GX Motherboard Logo
69 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
