Question about Refrigerators
Whirlpool fridge to cold
My fridge is way too cold, it freezes everything in there.  (Whirlpool, model # gd5shaxkq00).  We have turned the temp. control to off and there has been no change.  The freezer too is much colder than before but there is no frost build up in there.  Do you think it could be the cold control thermostat?  And if so, where is it located on the unit.  Is it something an average person could fix?
Thanks
  • 725 Answers
Both the thermostat and Adaptive defrost control are inside the fresh food compartment on top..
also check you damper it it is closing
let me know
Posted on Apr 05, 2008
My fridge freezes milk and everything in it
If the fridge is freezing everything, try this before thinking it's the thermostat first turn down the temp gauge in the freezer, not fridge to about medium, still a bit to cold turn down a little more. It save me heaps
Aug 13, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Whirlpool ED25RFXRWFreezer/Fridge temps unstable...either too hot
check the defrost timer but the cold control could be bad
Mar 01, 2010 | Whirlpool Freezers
Vegetable crispers freezing my vegetables
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 17, 2009 | Refrigerators
Whirlpool bottom freezer 5 years old everything freezes in the fridge
Oct 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge won't stay cold
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 08, 2009 | Refrigerators
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Freezer suddenly stopped freezing and fride is not getting cold
Hi, I would try putting your refrigerator and freezer control switches on medium. Good Luck,I hope this helps you out.
Nov 07, 2008 | Whirlpool Refrigerators
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
