Digital thermostat CM907 switches heating on the wrong way round, i.e. on when it is too warm and off when it is too cold
  • 86 Answers
1.check indoor wiring.
2 check thermostate.
3 check remote.
Posted on Apr 05, 2008
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
The blower starts before its warm and it blows cold air for about 30 sec when its shutting down .
When any unit 1st come's on, you'll always have some cold air that's in the ducts that will blow out before you get warm air. If your duct work is uninsulated in a cold basement or crawl space then it will be even more noticeable. When the unit is heating from the Heat Pump mode, it takes a little longer for the gases to get warm enough so you'll fell heat. When it gets cold enough for the unit to switch from heat pump to the gas or electric heat source, you'll get warm air faster. If you have gas heat, some Thermostats have an anticipator setting for the gas valve. If it's set wrong it will effect the on/off cycle of the gas valve.
All duct work in non heated and a/c spaces, including inside walls,above dropped ceilings, in attics and crawl spaces, must be sealed & taped at the seams and joints and then insulated and taped.
Most new construction has solved that problem with insulated duct board, flexible insulated supply's and special tape.
Dec 12, 2013 | Rheem 13PJL30A01-RHLLHM3617JA 2.5 Ton 14...
Honeywell cm907
there is no repair instructions or parts for this product
Oct 30, 2013 | Heating & Cooling
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
My whirlpool awz 231 does not dry clothes,i take the back of the machine and test for continuity at both the thermostats and the element,all seems fine,i start a warm cycle and it works for about 15/20...
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Nov 28, 2010 | Dryers
Heater blowing cold air antifreez full 1999 lincoln navigator
is there a thermostat for the heater loop the same as for the radiator loop on your car cooling system.
1 some cars have thermostats to keep the water just round the engine when the engine is cold and then they open as the engine gets warm to get the water cooled it seems that the water is not coming to the heating circuit so there maybe a thermostat valve that is stuck in the closed position and needs replacement
2 alterativly the heat control lever mechanism is stuck in the cold position and needs to be freed up or the control valve replaced.
3if the system is electrically controlled with no manual levers for heat control then a fuse may have blown or some other electical problem in the heat control mechanism.
Nov 13, 2009 | Lincoln Navigator Cars & Trucks
Heater doesn't work
How old, at a guess, would the thermostat be?
This will help in figuring out what might be wrong.
Dec 23, 2007 | Ruud Handler Air Conditioner
Honeywell digital thermostat won't turn off ac.
The Honeywell CT87 thermostat is a normal round thermostat, not digital and may have a sub-base installed with it that has a two switches on it. One is for Fan (Auto or On)and the other is for Heat, Cool and Off. Make sure the Fan switch is in the Auto position and the other switch is in either the Cool or Off mode. If you continue to get cooling, you have a short in the thermostat wire or a stuck relay in th indoor or outdoor unit. To test this, while the unit is running; remove the round outer ring on the thermostat by pulling it straight off towards you. You will find 3 slotted head screws that hold the thermostat to the sub-base. These screws are located at the 3 o'clock, 7 o'clock and 9 o'clock positions. Turn these screws counterclockwise with a small head screwdriver. They are held in place so should not fall and get lost. With the front of the thermostat removed from the base, the air conditioner should stop running. If the unit continues to run, you will need to have your A/C system inspected by a technician. If in fact your thermostat is digital, look to see how it is mounted to its sub-base and remove it. If the system stops, you may have a bad thermostat or the Fan switch is in the On position. Hopefully this will help.
Sep 11, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
155 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
