Question about Kenmore 63672 Convection/Microwave Oven
Rack in microwave
Do you have to remove the rack from the microwave if you are cooking something on the turntable?
the manual said it must be removed to pop porcorn, but I was wondering about vegetables and things like that if I am only cooking one item.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Amazing things you can cook in a microwave
Surprising Things You Can Cook in Microwave 559 960 0798
Posted on Aug 31, 2017
Where do you get cooking instructions for model#86043 the manual that came with it is useless,how do you get items brown.
Posted on Mar 02, 2010
You should not have any metals in the oven when the microwave is on. If you are just doing convection cooking, the metal rack should be in so that what you are cooking is raised up so the hot air can surround what you are cooking.
Posted on Dec 09, 2008
KENMORE ELITE #86013 Microwave/Convection Oven:Manual says always use Metal Rack when convection cooking.How can you cook whole chicken or roast? If you put food on top of the rack it will rub against
Yeah, that's an interesting dilema. You need to lift the food off the tray to get proper air circulation, but I've seen those racks and I understand that you don't have enough room to put a full bird in there! Is that by design, or an oversight? I don't know! And what can you do about that? Maybe you can cut off an inch off the support legs of the metal rack....
Oct 20, 2014 | Microwave Ovens
Cooking with convection oven
You do not have to remove the turn table, but I use the metal rack when cooking with convention.
Apr 15, 2014 | GE Profile PEB1590 1.5 Cu. Ft., 1000W,...
JennAir JMC7000ADW Microwave Oven Turntable not turning
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.
Dec 17, 2011 | Jenn-Air JMC7000 Microwave Oven
Turntable works intermittently
Good luck.
Nov 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The turntable doesnt turn. The clock, timer, start/stop and the heating do all work. How can I get this thing removed from the built in unit less than 4 years old
Good luck.....
Mar 19, 2011 | Microwave Ovens
The turntable is not working but I have power
Good luck.....
Mar 19, 2011 | Bosch HMT9656GB Microwave Oven
Turntable does not turn
Good luck.
Jan 13, 2011 | GE JVM1350BW/WW/AW/SY Microwave Oven
Microwave quit
Well first of all you can try to clean the turntable- Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable. With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing. If further you have the same problem then this could be a failing turntable motor...... Please post comments for further help or information.......
Good Luck!!
Thanks
Jun 25, 2010 | Sharp R-1610 Microwave Oven
I have a Maytag microwave, model# MMV5165BA and it has no heat.Everything displays and vent works but no heat.Can you suggest anything before I toss it out?
If it operates as normal but items don't seem to get hot it probably is a Magnatron failure (microwave producer). More times than not the repair / replacement of a Magnatron these days is not worth the investment, especially if the microwave is 4 years old or older ! You should be able to replace your microwave with a similar featured microwave / hood for about $300 to $400. You might try a JVM1750DMWW by GE great micro/hood for about $300, includes one touch sensor cook capabilities,300 CFM vent fan,removable rack,option to turn the turntable on or off, 1000 watts of cooking power. Good luck !
Nov 28, 2009 | Maytag MMV5165 Microwave Oven
Oven cooks but turntable will not turn, so it cooks unevenly. How do I reset the keypad so it goes back to normal factory presets, in case I entered something that stops the turntable revolving. Is there...
The manufacturer has set the rotational plate in motion at the same time the microwave tube is energized. They work together as a team. At no time should the plate be idol, unless you remove it completely, and then only the center spindle will turn by itself. It is possible for the rotational spindle in the center of the oven to break, but that is unusual unless some sort of pressure (like stopping it when it was moving) was applied. Also, it has been reported that some individuals tend to put items with too much weight or too large for the oven to manage; thus damaging the rotator. As long as the oven still provides Microwaves to cook your food, it is still OK. Years ago, there were no rotating plates and using the energy was all it took to get the job done. For even cooking, just manually stop the oven at times and turn the food to avoid over heating in one spot.
Jan 14, 2018 | Kenmore 62222 / 62229 1100 Watts Microwave...
Kenmore 63672 Convection/Microwave Oven Logo
336 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
