Question about Philips 9P6044C 60" Rear Projection Television
Blue Color GUN ( I want a buy one ??!!! )
Firstly, I have to tell you that my English is not my first language, so excuse me if you have difficulty to understand me.
I live in Montreal, Quebec, Canada.
I have a problem with my projection tv: I have the sound but not the image. When the power is on, at the back of the tv the color guns are red and green and there is a small orange light(LED), but the blue one doesn’t light up. It seems like some clear oily liquid have flew under the blue color gun. I think that the blue color gun has to be change, but I don’t know where to purchase one and how much it could cost. I think I would be able to do it myself, but I need to know if it would need an adjustment after.
Do you know where I can find a color gun? Can I purchase one by internet?
I hope that you’ll be able to help me.
Thank you.
  • mford428 Feb 14, 2009
    I do not have any blue when I checked the convergance on the TV. The picture is not clear.
  • Philips Master
  • 8,617 Answers
The blue CRT is leaking. This can be repaired by replacing the seal and installing new coolant. The coolant is corrosive and will cause solder deterioration but this is all fixable. I will post a link where you can get the servcie manual for your set which is a PTV840 Chassis. The site sells the service manual which they email to you right after purchase, and they provide free tech support that will help you each step of the way to repair your set, They also will have the new seals coolant and etc that you will need .Here is the link your manual is on page 2 of the phillips /magnavox catagory tittled PTV835-PTV855. Here is the Link. http://servicemanuals.vstore.ca/
Posted on Apr 04, 2008
  • 2,323 Answers
Check this site for info on how work on this CRTs. The process of repairing a leaky CRT is not difficult but time consuming and yes you will need to make adjustments after changing or removing the CRT.
You might have to change the circuit board assembly that is connected to the blue color CRT, or you can use rubbing alcohol and a soft hog hair brush to clean it.
Good Luck.
Can you please tell me what emotive language mean
when composing a sentence, you can write it as bare facts with no emotion
or you can write and allow your emotions color the message by using language that is more associated with your emotional state relating to the subject
rough example is
fact --the man committed a crime
emotional language --- the man committed a crime but he didn't mean it , was not himself, other excuses as to why he should be less that a convicted criminal
Apr 27, 2016 | Cameras
Ilo tv 32 hd problem
Excuse my English too. It sounds that the firmware to this TV has been corrupted by any way. A firmware update might be necessary. There is booting problem. If you wish to know more abut firmware update, check the site linked below. It has details to firmware update procedure to many brand TVs with illustrations. Beware, you must be sound in electronics to follow. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timslide option. The site is in English language, but have translation option, which can be pulled out from the right side of the display window.
Jun 28, 2013 | Generic 32 ilo lct32ha36 1080i hdtv...
Hi im green.my acer notebook 14 inches laptop is in arabic language.pls help me change into english.thank you
firstly go into your control panel then click on Clock,Language and region next click region and language then click format a list should come up then select the language you want
hope this helps :D
Apr 16, 2011 | Acer Aspire 4720 Notebook
Sir,I have motorola w200 cdma phone by mistake i have change it language and now i can't change its language please tell me how we can get english language.
Service codes Motorola CDMA: w150, w150i, w170, w170c, w200, w210, w355:
Set English language:
1. Menu
2. Down 7 times, Right soft button
3. Down 3 times, Right soft button
4. Down 1 times, Right soft button
5. Down 4 times, Right soft button
6. select language now
Aug 14, 2010 | Motorola Cell Phones
The color is screwed up
The projection TV has 3 color guns that focus to produce a single image. The 3 colors are red, green and blue. It sounds like the blue gun went out. You should be able to remove the back panel of the TV. If doing so, use caution as there is a mirror attached to the back panel. Once removed, you can confirm that the gun is not working. The fix, unfortunately is neither easy nor inexpensive. The problem could be simply a poor connection to the circuit board up to needing the replacement of a new light or perhaps a new gun. Unfortunately, there is no magic button to press and nothing you are doing wrong. This is a very nice TV and it may be worth getting an estimate to repair it. Or, perhaps this is a good excuse to go out and get a new 50" plasma! Hope this helps. If you can think of anything else I should know, please comment.
Apr 20, 2009 | Hitachi 57F500 57" Rear Projection...
Nokia 6220c change language
as u can change the layout of the menu in this phone ill tell you buy the pictures
settings is the folder with a spanner
phone settings is just a spanner
general is at the top of the list
personalize is at the top of the list (blue and yellow faces)
in that list you have
display
standby mode
tones
themes
language
voice commands
select language (5th in the list)
phone language is the first in the list
hope this helped
Apr 08, 2009 | Nokia 6220 classic Smartphone
Change the language from spanish to english on my tom tom one 3rd edition
This is from my tomtom one (not sure what edition) so the page numbers refer to mine.
1.Touch the screen for the menu
2.on page 1 of 3 on the menu, touch the blue wrench (change prefs)
3.press the black right arrow key to page 4 of 7 in preferences and touch the flags icon
4.press your desired language
Jul 17, 2008 | Tomtom ONE 3rd Edition GPS
Blue color gun off line
Milt,
What are you referring too when you ay the blue color gun is offline? Is the blue crt not lighting? Or just the convergence alignment off??
Bill
Nov 23, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Language
If you go to this link, you can download the english language drivers for your printer and scanner; http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=60421&prodoid=56291069&infoType=Downloads&platform=Windows and also the user manual etc. You probably have to uninstall the french version first before installing the english one, but make sure it downloads first in case there is a problem. Hope this helps, if not - ask again :)
Mar 19, 2007 | Epson CX3810 Stylus Color All-In-One...
Philips 9P6044C 60" Rear Projection Television Logo
100 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
