Question about Dryers
Won't dry After I washed a couple of loads the dryer works but doesn't get hot
  • 66 Answers
What kind of dryer is expl with m# thanks
Posted on Apr 04, 2008
SOURCE:
My dryer does not shut off and doesn't get hot. It takes almost 5 hours to dry a load of clothing.
Sorry to say but it sounds like the heating element is on its way out... Happened to ours and repair was more than a new dryer so we brought a new one
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Hot Point Dryer won't dry, gets hot on top.
An educated guess would be either the lint tube or the tube that exhausts the air outside is blocked with lint----no airflow or greatly reduced flow will cause this symptom.
Nov 06, 2012 | Hotpoint Dryers
My Hotpoint Aquarius WD420 does not wash properly. It doesn't seem to take in any hot water and the drum does not turn, it just sways from side to side and does not move on from wash to rinse and spin....
For those problems, you have multiple issues and need a service engineer. It may be just the hot water intake solenoid, but may also be a problem with the logic board or both.
Nov 13, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
My friend has an xqg65-11 all in one that she bought used. It worked fine for a few weeks, then started to not move to the next cycle, it just stopped. She has been manually clicking it to the next cycle....
There is a lint filter right under your washer door. You push that lid open, and you will find the lint filter. I have the same machine. but min is an xqg50-11. Is that a washer/dryer combo?
Jul 20, 2011 | Haier XQG50-11 Front Load Washer / Dryer
My dryer takes about 3 hours to dry one load, wer changed the coils, gut the problem is still the same, what else can it be?
Check to make sure the vent is not plugged with lint. Also wash your lint screen make sure it doesn't hold water sometimes they get a film on it and it won't let air by. Quick way to check your vent if you can't get to it........ Is to buy another flex pipe and run it outside and then dry a load of clothes and see how long it takes...
Jun 10, 2011 | GE Dryers
The dryer does not dry
time to clean the lint filter and the exhaust pipe (the large, white flexible hose) which could be filled w/ lint
good luck
May 20, 2009 | Whirlpool LTE5243D Top Load Stacked...
Dryer takes hours to dry ever since I converted to propane.
check for obstuction such as lint build up in the exhaust tube all the way out the house. Sounds like poor air flow
Mar 01, 2009 | LG DLG7188 Gas Dryer
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
66 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
