Question about Linksys Wireless-G Broadband Router
Use of router in network
I have a wireless-G 2.4GHZ Broadband Router. I have 1 wireless USB WG111T Netgear adapter. I have Road Runner Cable Internet provider. I tried to put the adapter in one remote PC and connect the router to the cable modem. I connected one PC directly to router. It worked for several months then my communications stopped with the internet. What did I do wrong? What should I do? Thanks for the help in advance.
    President:
  • 2,351 Answers
Try reset the router & cable modem. There ia a reset (very small) button on the back of the wireless router & the modem. Disconnect the power cords to both. Use a pen & hold in for 10 seconds (router & modem). Re-connect power (router & modem) & restart PC. If your service still has not returned. Chances are it's your internet provider & not you. Double check by connecting your modem directly to your PC.
Luck!
Mike
Posted on Apr 04, 2008
Netgear wireless adapter wg111t will not work work
It's impossible that the wireless router cannot detect your wireless adapter wg111t.
You try to test another one if still have a problem connecting with your wireless router.
If that router can see another wireless network available then maybe your Netgear wireless adapter have a problem incomplete installation or the wireless device is defective.
I have encounter like this before so maybe it's the same with.
Hope my tip will help you a lot.
Please rate me.
Thank you.
Sep 14, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Re set wireless usb adapter
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  3. Click Wireless Settings under Setup menu.
    1. Under Security Options, Select WEP (Wired Equivalent Privacy)
    2. Change the option to Disable
May 18, 2009 | NetGear USB 2.0-Stick WiFi 108 Mb WG111T...
Sierra Wireless AirCard 595U And PS3
I understand that you want to connect the PS3 using the Wireless card and NETGEAR card. Please note that the setup you have will not work for internet access. You can not configure the Air card to work with NETGEAR router. you need to have wih a broadband connection available for this router to connect to internet.
Once you have the router configured with Internet access then you may either connect the PS3 wired or wireless to the router, like you connect a desktop or laptop to the router.
Jan 12, 2009 | NetGear WGR614 Wireless Router
Periodic Lost of Conection
I experienced this problem before, what mine turned out to be was that when I configured the router to accept a passphrase the problem would appear it worked fine without the passphrase but this is not secure at all. I tried a few things, but nothing worked. I ended up getting a NetGear Router.
Hope this helps
Sep 13, 2008 | Belkin F5D9050 Wireless G Plus MIMO USB...
I have a wireless netgear usb adapter and nothing else, its not installed on my computer and I want to put it on, it wont work, what do i need to get my usb wireless adapter to work??? It is a wg111t...
You first need to install the driver. You can download it here:
http://kbserver.netgear.com/products/wg111t.asp (it should have came with your adaptor)
You must also have a wireless router available for this to work, or in an area that has WiFi available.
Jul 17, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Wg111t wire network
run cmd ( windoowsxp) then type ipconfig you should see an address like 192.168.2.3 if not goto network conections and view all goto wireless connection -properties then tcip set for auto config and then ok make sure your router is set for WEP sercurity type in a ten digit hex code ( 28 34 f6 a7 c3) and then save . rescan for your network then log on make sure you have GOOD signal strentgh . the wg111t does not work well with belkin routers.
Dec 25, 2007 | NetGear WG111T 108 Mbps 802.11g Wireless...
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER
Configure router via ethernet cable in first instance. Then install adapter. May need to hange MTU for AOL as ISP.
Oct 08, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
Linksys Wireless-G Broadband Router Logo
110 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
