Question about Microsoft Windows XP Professional for PC
Problems in my desjtop
I can start my comp and do what i want but it is not shutting down and i am forced to shut off the power supply. also my comp hangs up a lot when i am using certain applications. please solve.
  • phoenixZ Apr 04, 2008
    any solution?
    Scholar:
  • 160 Answers
Hello
      If your system is delaying in the shutdown process it may be the required INF files missing in the OS.  If that is so you need to re-install the OS and make sure that you may shutdown the system properly and do not swith off the system directly.
Let me know if your problem is solved and rate me as FIXYA!
Posted on Apr 06, 2008
Hi
for this problem you need to reinstall the operating system I think shutdown.exe is missing in your system.
Posted on Apr 05, 2008
  • 818 Answers
Seems that you have some virus o spyware in your computer, that slow your computer, go to www.nod32.com download the antivirus and see how is your computer.
Sergio
Posted on Apr 04, 2008
SOURCE:
What's your problem?where is switch located that shuts off NV52 when lid closes
go to control panel /appearence personisation /system security go downtoo power optionsedit plan settings (change when comp goes to sleep /change advanced power settingsbox will open power options work way down to power buttons and lid open that up + on battrey open lid close action you will see do nothing open that up and press shut down
that will shut down youre comp when lid closes
Jul 16, 2012 | Gateway NV5215u Notebook
When i turn on my laptop,the fan just run for a while then stop and my laptop become blank like force shut down
Power drain would be a better solution in this case.first shut down the comp.unplug the charger. remove the batteryand after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Oct 23, 2011 | Lenovo IdeaPad S10-2 Netbook
My comp shuts down at least once a day. i shut it off wait a few sec and start it back up, seems to be good for several hrs. i have run ccleaner and microsoft essentials and they both allways say there is...
it could be a power supply issue.. shut down the computer
remove all connections that go to the power supply , look inside the connectors and inside the mainboard coinnections, make sure there is no corrosion or dust in the connections
use something , like CO2 air can to blow off the dust from the mainboard..
plug all connections back.,. start computer ..if problem persist, it couls be a hardware or s/w compatability issue.
Nov 01, 2010 | Computers & Internet
PS3 shut down, wont start. HELP!
The power supply module has likely failed. Sorry, you will need a service shop. Attempting to FORCE out the disc can cause EXPENSIVE repairs.
Apr 17, 2010 | Sony Playstation 3 (PS3) Console
Overusage of computer HELP!!
yes hibernate is as good asd a shut down
u need to remember it is better to shut your comp down always when you are not using it
Jun 16, 2009 | Dell Inspiron 1521 Notebook
I re-started my toshiba A135 laptop, and the screen went black
There are dozens of possible root causes for your problem I guess.
But exactly the same happened to me in fact on a packard bell laptop. After my son forced it to reset, it didn't start again. Only one led was lit. After a long search I found that the battery had died and this prevented the laptop to start even when the power supply was plugged in.
Try this: remove the battery, connect it to the power supply and restart.
Hope that helps
Jan 24, 2009 | Toshiba Satellite A135-S2276 Notebook
E-machine computer will not shut down
When you say "it will not shut down", are you referring to clicking on start and then shut down?
You could try forcing a shut down by holding the power switch down for about 5 seconds.
Jan 18, 2009 | E-Machines eMachines Desktop PC
Tv shuts itself off
The power supply may be going on to protection mode. This is usualy because one of the scan amplifiers may have failed, or something is taking too much current and forcing the power supply to shut down.
Jerry G.
May 12, 2008 | LG RU-52SZ51D 52" Rear Projection...
I recently purchased a Toshiba A200 laptop. When shutting down, I pressed "Hibernate" and I now cannot get the laptop to start. Can you please help??
push the on/off button once, to try to open the comp (does not matter that it won;t open), than pres the button continuosely for about 6 seconds (to force it shut down) and than press again once to open ....
if that does'n work than depanding on the OS u;re useing, u have to force the OS to start in normal mode or to check it's self. (for windows, press F8, than u;ll have a start normal mode option ...)
Apr 22, 2008 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
