Question about Nintendo Wii Console
Wii power supply
My wii no longer has a power supply. Ive tried plugging it in other sockets, plus checked the fuse and the connection to the wii.
  • 1 more comment
  • Anonymous Aug 29, 2008
    Cannot turn on the Wii. I have tried other electrical outlets and tested the existing one. It simply won't turn on
  • asypek Nov 26, 2008
    Where is the fuse on the power unit?
  • calebalderma Mar 26, 2009
    happend to me to tryed pluging itt in to other out lits checking if it was in right no good no power at all
To reset the AC adapter you need to unplug it from the wall outlet and the Wii console and wait at least two minutes. Plug it back in and it should come on. If you have it plugged in a surge protector with other appliances, the other appliances may be interrupting the adapter, causing the power to go off.
Posted on Dec 12, 2008
  • Thomas Venne Aug 12, 2011
    After cutting the end off and splicing it on another 12 v supply and finding that didn't work, I was going to buy a new supply. Then I read the above about waiting a couple minutes. Spliced the end back on the WII power and it worked. Thanks for saving me some money.
    Problem Solver:
  • 5 Answers
Sleeslack's solution works for me. I had determined that it was the PS, as there wasn't 12V available at the connector. I had other web hits that said it was the 2.5A fuse inside the PS, and was looking for special screwdrivers, etc, and faced with finding my soldering equipment- Glad I ran into this. Usually it only takes <30 seconds, so although I had tried unpluging- I didn't wait long enough. this suggests there is some sort of thermal circuit breaker that needs time to cool off to reset. Glad it wasn't the fuse. I'll be pluging into my entertainment system UPS to avoid this happening next time there is a surge...
    Scholar:
  • 119 Answers
It could be the power supply, or it could be the Wii itself.
If you have a friend with a Wii, try taking your Wii over and plug it into their power supply.
You can also do the troubleshooting from Nintendo's site:
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp
Posted on Apr 05, 2008
    New Friend:
Posted on Aug 12, 2011
  • 26 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
2015
Posted on Apr 03, 2009
6ya staff
SOURCE:
My child plucked my wii game in22ov socket how to repair it?
When your child plugged the unit into 220VAC outlet, it probably shorted out the power supply Either the FUSE or the power supply itself got "fried" Unfortunately.There may be 4 diodes that are called Rectifiers that probably got burned out when unit was plugged in.
Sep 12, 2014 | Video Game Consoles & Games
We just got our we, we plugged it in then the power in the whole house went out and the wii won't turn back on - HELP
My guess would be that the fuse in the plug has blown. Try replacing the fuse and try plugging the power supply back into the mains power socket but do not connect it to the Wii. If the power goes again and the fuse blows then the power supply is faulty. If the power in the house stays on then try plugging the power connector into the Wii and see if it works.
Feb 24, 2011 | Nintendo Wii Console
OK i went to go turn on the wii the light wont come on and it will not come on at all. What should i do and what should i check???
You need to check that the power supply is working. To this safely you will need a voltage meter. You can buy multimeters from most electrical or electronics stores such as maplin. On the power supply there is a diagram showing the power pins and the voltage output. You should be able to read 12VDC across the pins when the mains power is connected. If there is no 12VDC then check the fuse in the plug. This is a 3A fuse and it can be easily removed from the plug with a suitable flat blade screwdriver. Use your multimeter on resistance (Ohms) setting or on continuity (bleeper) setting and test across the two ends of the fuse. If the resistance is nearly zero or the multimeter bleeps then the fuse is OK. If the fuse is Ok and you mains socket has power but there is no power output then the power supply is faulty. If there is 12VDC out of the power supply then the Wii is faulty. If it is under warranty then take it back to the store. If it is out of warranty then get someone to fix it (if possible).
Feb 20, 2011 | Video Game Consoles & Games
Error remove disc and turn power off follow the manaul
First turn the Wii console power OFF, and remove the AC adapter's AC plug from the power socket. Next, check wheather the disc is dirty or scratched. If it is dirty, gently wipe with a soft cloth from the center to the outside. Wait about 5 minutes. Then plug the AC adapter's AC plug back into the power socket and turn the console power on. If the same message still appears, the Wii console may be damaged. Turn the Wii console off immediately. Remove the AC adapter's AC plus from the plug, and visit support.nintendo.com for additional troubleshooting or call 1-800-255-3700.
Jan 05, 2011 | Nintendo Wii Console
System will not turn on
Can you borrow a friends power supply and try it? I presume you checked the fuse in the plug socket (If a UK plug.).
There is a fuse in the power supply which could have blown.
There is also a fuse on the power inlet on the Wii motherboard (it is coloured green). That could have blown.
After that there are over 40 fusable links on the motherboard!
Jul 24, 2010 | Nintendo Wii Console
My Wii Console will not turn on.
Short the DC end of the cable, ie;connect the two terminals with a paper clip, this will discharge the capisitors and reset the unit.
Mar 07, 2010 | Nintendo Wii Console
Why wont the wii power on
please check all power and connection cables to make sure that everything is connected correctly. If that does not work then please change outlets and see if it works better. If that does not work then you have a hardware defect which should be covered under warranty with the manufacturer so you should contact them for futher assistance.
Mar 04, 2010 | Nintendo Wii Console
My wii console will not turn on at all, the blue light will not come on. I have checked all plugs and cables and everything is connected. We have only had this wii console not even a year yet. what could...
it could be the power suppy mine went wrong after about 18 months, try ebay there the cheapest. you can test if its the power supply if you know someone with a wii and use there power supply or know how to use a multi meter and check if you have a voltage coming out of the wii plug end. if you dont first try replacing the fuse in the wall plug. hope this helps.
Nov 11, 2009 | Nintendo Wii Console
My wii console will not power on. have checked all plugs and everything is connected and outlet has power
HI. the power supply board has failed. There is a fuse(3amps) inside the power supply unit. you will need to remove the cover from the power supply to access this fuse. once inside the power supply, inspect the fuse. if it is truly blown, replace it. if the fuse is not blown, this will confirm a failed power supply unit. it should be replaced in this case...
Aug 04, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
4,628 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
