Disk boot failure
When i turn on my pc it says disk boot falure enter systems disk and press enter
  • Anonymous Apr 01, 2009
    acer aspire l320 desktop
  • 13,434 Answers
There are multiple reasons for this
1. hard drive failure
solution: replace hard drive reinstall operateing system
2. computer is not set to start from hard drive
solution: enter bios and set computer to start up from hard drive
3. Hard drive not detected or cable loose.
solution: check are the hard drive cables connected well. try disconnecting and then reconnecting.
4. Hard drive file system corrupted and unable to find start up files
solution: you can use the windows xp to enter repair console and try to correct the corruption with chkdsk command if that doesnt work you have to reinstall operateing system
Posted on Apr 04, 2008
  • Ekse Apr 04, 2008
    I ment windows cd not windows xp.*****
SOURCE:
Disk boot problems
Insert your OS disc to repair the damaged boot sector and then replace the hdd as that could be the cause.
Sep 11, 2014 | Computers & Internet
Getting message "Disk Boot Failure Insert system disk and press enter" using window xp platform and have MCA fee antivirus software
this happens either the boot sequence have changed or your hard drive is not recognised by the BIOS
Jan 26, 2013 | Computers & Internet
When i turn on my PC toys CPU and emachines monitor it says disk boot failure enter system disk
hi,
you have two option as follows:
1.when you start PC press F2 enter in BIOS set it to boot from HDD then restart,if this step does not help then number 2
2.reinstal the OS
Sep 26, 2012 | E-Machines eMachines Desktop PC
Disk boot failure, Insert System disk and press enter---error message when turning on the PC HPa6230n. PC will not recognize pressing F8 or F11 repeatedly.
your hard drive has died and needs replacing. if you have to ask how to replace it you need to take it to a repair shop.
Jul 03, 2011 | Computers & Internet
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
When turning on my acer aspire desktop a black screen comes up with the following and wont start up: Verifying DMI Pool Data...... Update Success Boot From CD: DISK BOOT FAILURE INSERT SYSTEM DISK AND...
Ensure that you havent got a cd in the cd rom then reboot, press F2 or Delete to enter the bios and look for boot options, set the primary boot to your harddrive press F10 and press y to save and exit the bios, Press F11 and set that to boot from harddrive and let the computer boot, if it still dosent boot to windows then the hdd has become faulty, or has been wiped of the operating system and windows will need to be reinstalled.
Aug 21, 2010 | Acer Aspire™ T180 PC Desktop
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Disk Boot Failure
Any system can be recovered, although it depends on what is wrong.. this error can mean no info on the hard disk, or damaged hd...more than likely whoever had the computer erased it for data's sake...I would've...get an os and load it.
Aug 08, 2009 | Computers & Internet
My system is not entering windows environment.its showing "remove disks or media. press any key to restart disk boot failure, insert system disk and press enter"
1. Check, if you HDD is alive:
Boot the PC with Windows CD. Enter Recovery Console. More Information here:
http://en.wikipedia.org/wiki/Recovery_Console
Try some old DOS commands like:
- c:
- dir
Here is the full list of commands:
http://support.microsoft.com/kb/314058
Try to check the disk using CHKDSK:
http://en.wikipedia.org/wiki/CHKDSK
2. Recreate Boot Sector and MBR using commands:
- fixmbr
- fixboot
Don't worry. It doesn't affect you data!
May 03, 2009 | Computers & Internet
Open Questions:
Computers & Internet Logo
170 people viewed this question
Ekse
Alun Cox
