Question about Asrock P4I45G Motherboard
BIOS battery aim using Asrock 845G mother board the system date date is showing wrongly when ever i switch on the system. and i have changed the BIOS battery even after changing the battery same problem repeated. how to get rid out of it.
  • 13,434 Answers
I supose you have set the correct date in bios?
Posted on Apr 04, 2008
SOURCE:
My CPU keeps showing BIOS checksum error when booting up even i changed the battery with a new one
Remove the BIOS battery fr approx. 15mins (this will reset the BIOS back to the default settings) then insert the BIOS battery and configure the BIOS Date and Time etc.
Mar 22, 2011 | Asrock P4I45GV R5 Motherboard
I am not getting display. why?
Hi,thanks for using fixya,
Switch off the computer and open pc cover.
First check the ram, clean by eraser or with solvent and install again ,if the problem same install thre ram to another computer either it damage or not .If the problem is same change ram.
http://en.wikipedia.org/wiki/DIMM
http://www.pcbuyerbeware.co.uk/RAM.htm
If same as before, remove the cmos battery or clear the cmos jumper and hold " on off "switch for 40 seconds. Install battery again and start pc .
Now please check the "smps" by another new or by your "smps" to another pc to confirm either it damage or not.shibuda_44.jpgshibuda_43.jpgshibuda_42.jpg
http://site7.way2sms.com/jsp/Main.jsp?id=6BEFB035C72C9BC7795F7E8D4A2E60B9.a403
http://www.playtool.com/pages/psuconnectors/connectors.html
If same as before now please take a risk and ready to chip label repair,
1.Change all the capacitors, beside the processor, with the help by nearest technician.
2.Set an identification Mark, on the bios chip, by the permanent marker because you need to remove and install it.It could not be possible for all mother board .
3.Remove bios chip from base , clean with solvent and install it proper again.
4.For Intel mother mother ,install a flopy drive and switch on the power and,follow the flopy drives "led light", either it glow or not.
If the flopy drives led light on,download bios filre for your intel mother board ,paste on flopy.follow the bellow link for download.
5.Now don't switch off your motherboard at the time of updating the bios,so please use an ups,and insert the flopy, along with bios file.Set the cmos jumper in recovery mode( just change the normal position ),and switch on motherboard, hope, through this proceses, should recver the mother board.
If the problem is same, I will recoment you for new motherboard.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 23, 2011 | Asrock P4I45GV...
My mother go to setup every time i shut down the computer or turn off power
- set date time in bios or disable floppy drive
- change the battery on your mainboard
Apr 27, 2010 | Asrock 775i65GV Motherboard
Reset A Bios of Asrock mother board
go to the following site
http://www.asrock.com/mb/manual.asp?Model=K7S41GX&s=462
download the user manual(not quick installation guide) and check page no 7 or content 1.3 to get the jumper pins to reset the motherboard.
just short those pins and the cmos settings will be gone.
another simple method is just remove the battery and wait for 5 min and again plugin the battery.
thats it you motherboard is resetted to factory settings.
Apr 21, 2009 | Asrock K7S41GX Motherboard
CMOS Battery do no work
Just change your CMOS battery with a new one and after that goto the bios settings and update the time and dare.
After that just save the settings and then check that the warning message is coming or not.
If its coming then it means you need to change the CMOS jumper settings.
Mar 09, 2009 | Asrock 845GV (P4I45GV) Motherboard
PC HARDWARE
Change the mother board battery it is flat when you change battery you will have to reset BIOS to your time and date
. Also your CPU and memory settings may have to be reset as well
Nov 01, 2008 | Intel Motherboard
My computer is not working
have u tried to boot into bios switch it over to optimal settrings or default settings and save and try to reboot
Aug 17, 2008 | Asrock 775i65GV Motherboard
Compatilblity with 845G mother board
try update the system bios because there were motherboards that had compatibility problems, this board is not a new one so it should work with your processor
Feb 07, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Open Questions:
*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]
Oct 17, 2019 | Computers & Internet
AVG customer service phone +[-\@;-{+1'8OO;8O3^1O69}] NuMbEr USA .Anita This AVG USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 AVG USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the AVG USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, AVG USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVG USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AVG USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AVG USA Calling AVG USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVG USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVG USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVG USA's phone numbers against each other. Contacting AVG USA in General While I8OO8O31O69 is AVG USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach AVG USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVG USA.Anita
Oct 17, 2019 | AVG Computers & Internet
See all Asrock P4I45G Motherboard Questions
Asrock P4I45G Motherboard Logo
111 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
