Question about Kyocera Mita KM-3035 All-In-One Laser Printer
KM-3035 How do you view or configure the IP Address from the front panel.
  • macdrphd Apr 08, 2008
    Much appreciated, will give this a try.
    R:)
  • 36 Answers
Machine has to be ready to Copy.
Press the "Printer" button, touch "Printer Menu", "Interface","Network","Detail".
Arrow down to TCP/IP, touch "Change#".
Now you can see the current IP address.
Touch "Change#, and enter the new number with the key pad.
Hit "Close" 4 times and touch the Copier button to return back to home.
If you hit the "Back" key at the end, it will not lock in your changes. It will just back out.
Posted on Apr 08, 2008
SOURCE:
Unable to change names/add addresses in the address book faxing
Try Googling (Kyocera)(KM-3035)(manual) without parens for instructions.
Nov 03, 2017 | Kyocera Mita KM-3035 All-In-One Laser...
When i print envelope the return address gets cut off
There are some parameters that must be correct before an envelope will print properly. The M/P tray on the KM-3035 should be configured for the proper envelope size, probably COMMERCIAL 10, (but could be another size...need to measure the envelope) and type should be set to ENVELOPE. When printing from the application,i.e. Word or Word Perfect, be sure to select the proper printer and configure the Print Set-up, print direction, size, etc...You will have these options by clicking file and then print from the application print menu.
Dec 07, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera 3035 will not print - NIC card red LED flashing
First turn the main Power Switch off, then unplug the network cable from the nic card and leave it unplugged. Then turn the machine back on, when it says ready to copy, press the printer button and print out a network status page. Then hook the network cable back up and go to a pc and click on start then control panel and look for printers and faxes and click on it, then right click on the Kyocera Printer Icon, then click on properties in the drop down then click on the port tab, then click on configure port and check the ip address and make sure it matches the one on the network status page, if it doesn't put in the correct IP Address and apply the change. But if the ip address is right just try printing again. If it prints ok then you are done but if it doesn't try this click on start then run and then type in cmd, then on the screen that opens up type in ping, then a space, then ip address of the Kyocera Machine then press enter, if the Nic card is connecting to the network you should get a reply from the Kyocera's Nic Card if you do then the Nic Card is ok and the Kyocera print driver may have to be deleted and then re-installed. Hope this helps.
Aug 06, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
My laptop stopped recognizing scanner
the printer and scanner have separate tcp\ip address's
on copier panel check system default/counter key go to scanner and check ip address also make sure file manager is running on laptop
Apr 02, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
What is the code for KM-3035 printer's scanner network card?
Print/Scan System (U) 083H9503 Network Print Controller and Network Scanner
Feb 12, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Scan question
Through the web browser. Enter the ip address of the scanner section into Internet Explorer.
Jan 28, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Setting up wireless printer
To assign an IP address to a KM 3035 you need to select the system menu/counter button above the touch screen. On the left hand side of the menu you need to select Printer Defaults. From this menu you need to select Interface and than select the network tab from the resulting screen. Scroll down to highlight TCP/IP and select change. From this next screen you should be able to assign a new IP address.
Let me know if you need any further info.
Henry
Jul 26, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Scan a document to my file server
that's in scan settings from print manager..
May 03, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera-Mita going offline
Try an updated driver from the manufacturer or see if they have any know issues with 2003 sp2 and the driver.
Hope this helps!
Nov 27, 2007 | Kyocera Mita KM-5035 Printer
KM-3035 scanning issues
the 30/40/5035 series machines have two network cards in them. One for printing and one for scanning. and they have separate IP numbers also. make sure you have scanfile utility running on your pc or wherever you are sending the files and the folder set up in the utility. then set it up on the scanner network card.. Not the printer.
Oct 15, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
2,358 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
