Question about Konica Minolta DiMAGE Z5 Digital Camera
Dimage z5 i need the driver for my camera
  • Anonymous Jun 27, 2008
    I need drivers for my Konica Minolta Dimage Z5 camera for Vista, I can't se the pictures neither on the camera or onthe SD memory card
I have formatted the sd card and now I can se the picthures
Posted on Sep 04, 2008
SOURCE:
I require the driver for Vista O/S for the Konica Minolta DiMAGE Z5 Digital Camera.
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jul 12, 2011 | Konica Minolta DiMAGE Z5 Digital Camera
Tip
I have almost identical issue with a Dimage Z5 (Konica/Minolta). I have had the...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Dec 01, 2007 | Samsung Digimax D53 Digital Camera
When inserting SD Card in to Dimage Z5 the camera will not read card. (''Unable to use card.) Please help.
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-z/dimage-z5/compatibility/detail.html
Your card is probably not supported by the camera.
Jul 05, 2009 | Cameras
My Konica Minolta Dimage z5 won't play back photos
What size memory card are you using? I have had this problem trying to use a a 4gb card, which apparently is not compatible with the Z5. Using a 2gb card seems to alleviate the problem.
Jan 03, 2009 | Konica Minolta DiMAGE Z5 Digital Camera
Same SD card problem with Dimage Z5
Your Card may need to be formatted. to fix this problem:
[note- before you start, make sure that your SD Card is blank, or that the information is unimportant, because formatting your card will erase all of the information.]
1) Plug the card into your computer, if you can, in the SD slot, or use a USB - SD transformer to plug your card into a USB port.
2) After its plugged in, go to 'My Computer'.
3) Right Click on the drive its plugged it into
4) press format
5) Make sure all of the correct settings are on and start the format.
now your SD card is formatted and should work in your camera and you can continue taking pictures. YEA :^)
Apr 13, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
ANTI-SHAKE TURNED OFF
  • Switch camera on
  • Select Menu Button
  • Menu item 1
  • Use controller to move down to anti-shake
  • Use controller to move right
  • select i) Disp + Exp ii) Exp only iii) Of
Go to http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-z/dimage_z5/Z5_OM_E_.pdf for a Z5 manual
Jan 26, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
What print size can the DiMAGE Z5 provide at maximum?
Approximately up to B3-size (43.3 x 32.5cm) is available when printing at 150dpi.You can print on up to B5-size (21.7 x 16.3cm) for photo-quality at 300dpi.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
What type of CCD is used?
The DiMAGE Z5 uses a 1/2.5 inch interline primary-color CCD with total of 5.2 million pixels.
What is the operative temperature of DiMAGE Z5?
It is approximately 0 to 40 degrees centigrade in temperature. (5 to 85% in humidity)
Konica Minolta DiMAGE Z5 Digital Camera Logo
124 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Ekse
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
