Question about Insignia NS-DV2G MP3 Player
Power wont stay on
When i hook up the usb cable it turns ons for 30 secs then off again. This is all it will do it wont charge.
  • Jleec1992
    Jleec1992 May 04, 2008
    Mine wont cut on and wont even charge i know the battery is good.
  • Nic Ashby
    Nic Ashby May 11, 2010
    Will it power up and stay on normally if you do not have the cable plugged in?
Its the battery i believe, i took mine into best nuy [where i bought it] and they told me to pick a new mp3 player of same or lesser value because that mp3 model was discontinued [but i had bought a 2 yr replacement plan because i knew it would fail me eventually]
Posted on Apr 26, 2008
Samsung tab 3 10.1 CE0168 Wont charge or come on ?
have you tried a hard reset?, take battery out and disconnect from power supply then hold power button for thirty second then replace battery and try to power up else hold power button and volume down for 30 secs need to keep battery in for this one, if they dont work you need to contact samsung to get it repaired.
Feb 06, 2017 | Samsung Tablets & eReaders
Etouch android wont charge
switch off.wait for 5 mins.
connect to pc or laptop with usb cable.
press & hold power button till it turns on then off.
press power button for 3 secs.it should work.
if no luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
Jun 27, 2012 | Tablets & eReaders
Wont turn on
well maybe there is the lince stucked what you can try plugg it to a usb cable and that to a extern cable to the charger cable for usb once you see the light you take the usb cable out of the fotocamera should open now . but propably the fotos have on the side some damage -
Apr 17, 2012 | Nikon COOLPIX S5 Digital Camera
My HP Pavillion laptop g61 wont turn on or off. There is no fan running it doesnt sound like it is on but the power button light is on and wont turn off. The screen just stays black. I have tried charging...
I had trouble looking up that model on the HP page, but you should check this page and see if this model is affected by this NVidia litigation. If it is, you can get it fixed/replaced on NVidia's dime.
http://www.nvidiasettlement.com/affectedmodels.html
Oct 15, 2010 | HEWLETT-PACKARD Pavilion G61631NR Notebook
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
My w980i phone wont turn on after i disconenctede it from my computer
its a w980 software problem, very common
the solution is to open up sony ericsson pc suite
then under tools click "phone repair" and follow the prompts
if this fails it means your battery is dead, try charging it and try again
please note this will restore phone to factory state
Oct 29, 2009 | Sony Ericsson Walkman W980i Cellular Phone
HP Photosmart C5180 All-in-one error Oxc18a0301 I replaced 2 ink cat with proper ink. Now I get error oxc18a0301
Perform the normal assert troubleshooting:
-turn ON the printer
-disconnect the usb cable from both ends of the printer and pc if printer is connected with USB cable
-open the cartridge door and remove all the ink cartridges
-close everything without installing the cartridge
-disconnect the power cable from the back of the printer without turning off the power
-wait for 30 secs
-plug the power cable back in and install all the ink cartridges if the printer turns on
-wait the printer to initialize and stop making noises
**don't attempt to print this time
-turn off the printer by disconnecting the power cable from the back
-wait another 30 secs
-plug the power cable back in and if the printer is ready to go
-try printing a test page
Get back to me if it doesn't work.
May 31, 2009 | HP Photosmart C5180 All-In-One InkJet...
Toshiba quosimo f45. laptop wont boot at all ,fixed once by them
hi there,
dont panic brother,
try theses things.
--> take out battery
--> connect the power cable
--> wait for a minute
--> turn it on
--> it will work
if not
--> take care power cable out
--> put the battery in
--> turn it on
--> and it will work (try to move the lid up and down)
if not
--> charge the battery dont turn it on
--> when its full take of the power cable
--> wait for 30 sec
--> turn it on
--> it will work ((try to move the lid up and down)
if not
--> keep the power cable
--> turn it on
--> it will work (try to move the lid up and down)
best of luck
Mar 23, 2009 | Toshiba Qosmio F45-AV410 Notebook
All the lights are lit up and when I close the printer down within 2 seconds they are back on also it wont print anything.
disconnect the power and usb cable from the back of the printer and press and hold down the power button for 30 sec and then reconnect the cables and try again...open the backdoor and try to move the rollers in upward direction.Make sure the unit is connected directly to the walljack.
Nov 27, 2008 | HP Office Equipment & Supplies
Camera Wont turn On: Is it stuck in USB mode? How do i fix it?
I was able to get past this problem by removing and reinserting the battery. This caused, in effect, a hard reset of the camera, which let me power it up fresh and take pictures again. Of course, it's not exactly reassuring that the problem arose in the first place,
Jimmo
Nov 04, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Insignia NS-DV2G MP3 Player Logo
20 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
