Question about GPS
Our StreetPilot c530 froze up with the screen on as we were entering a new address. We can't turn it off with the side button nor elicit any action from the screen. We tried both the car cable in the car and the car cable with the wall adaptor to see if that would maybe restart it but no change occurred. Thank you. Richard
  • rbdlong Apr 04, 2008
    After letting the unit sit unplugged and with the screen 'on' for several hours, it turned off.  I then plugged it into a wall out let with the charger cable and so far it seems like it's back to functioning normally.
    (There doesn't seem to be any way I could open it to look for a battery although it does normally operate for hours as a hand-held with no power attached.)
    Thanks for the advice.
    rbdlong
  • 3,037 Answers
Have you tried removing the battery?
Posted on Apr 04, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 04, 2008
    or does it need to be plugged in to run? I would expect some kind of battery to save some info
  • Benjamin Patri
    for some reason these systems will freeze up and in most cases they are deemed unrepairable, if you can, I would return it and get a new one or a different one because this is a common problem and as far as I see, Garmin doesn't have a solution to this.
  • Benjamin Patri
    no problem
Garmin c530 just gets warm, won't power on, won't charge.
try resetting the unit by popping off the frame around the screen where the reset button is.
Oct 23, 2009 | Garmin StreetPilot c530 GPS Receiver
My c530 won't turn off and the sreen is froze
Unplug the GPS for a couple of minutes and turn it back on. It sounds like it just froze up and needs a good power cycle. Let me know if this helped! Good luck.
Aug 02, 2009 | Garmin Streetpilot C530 Car GPS Receiver
Garmin c530 does not turn on
Replace the battery 3 years is the maximum life of the battery
Jun 11, 2009 | Garmin StreetPilot c530 GPS Receiver
How to reset garmin c530? thanks.
Pull the face off, press reset button under it,
then update it at Garmin's Web-updater website.
If it wiil not reset like this
Press the lower right corner of the screen, while turning on, keep pressing until the message
" do you want to remove all data " appears, click yes
Then re-register it at Garmin, then re-update it at Garmin
Should be good then
Regards
Richard.
May 18, 2009 | Garmin StreetPilot c530 GPS Receiver
Touch screen doesnt work all the time
Pop the face off to reset it, could sort it for you.
Press the power button for over 1 minute to calibrate the screen
and use the Garmin Web-updater to update the software.
Should be good then
Regards
Richard.
Apr 15, 2009 | Garmin StreetPilot c530 GPS Receiver
Does not select the letters that you want
I saw that someone suggested that I hold the power button for several seconds
until i got more on screen instructions - follow the bouncing dot and it seemed to
clear the problem - time will tell
Apr 12, 2009 | Garmin StreetPilot c530 GPS Receiver
Just a question
Unfortunately, no. Once gone from the unit, it is gone and must be re-entered. Sorry.
Apr 03, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin c530
Carefully remove face plate bezel. There is a reset button on the right side of the face. Press the button and then restart normally. It's in the owners manual if haven't lost yours like I did. The manual is on Garmins website.
Feb 16, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 street pilot
My Garmin c350 has a green screen after trying to update it for the first time and my computer will not read that it is connected.
It will not shut off after holding the power button down for 3 minutes
Dec 13, 2007 | Garmin StreetPilot c530 GPS Receiver
GPS Logo
23 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
