Question about Mitsubishi HS-U748 S-VHS VCR
Replace our VCR
We have a HS-U748 and need to purchase another VCR as backup were this one to fail. It is doing mission-critical tapes for a Cardiology office. Any thoughtson a suitable replacement/stand-in in case this device fails/needs to be repaired?
  • Anonymous Apr 01, 2014
    I have tried everything I can google, and even downloaded the manual.I think the time change messed itup
    Master:
  • 518 Answers
I see someone selling that exact model on Ebay. Or there are many other Mitsubisha S-VHS similar in Model. I would stick with what you (they) are familiar with.
Hope that helps...
Geno
Posted on Apr 04, 2008
Mitsubishi hs m50v
I forget exactly how this goes but there are two posts on either side of the mechanism that read a light signal and a center pole that goes through the round hole on the cassette that gives the light signal (no tape-end of tape). Put a piece of tape on the two side posts and see if that changes anything. Be careful: the tape now knows where end of tape is - do not fast wind/rewind to the end! The loading motor may have failed or a rubber belt has slipped off or is too loose or broken.
Oct 20, 2013 | Mitsubishi HS-U445 VHS VCR
I have a Mitsubishi HSU48. The tape is stuck in the VCR. I cannot get it out. Do you have any suggestions
I had this problem with this specific machine. These answers have all been general to any VCR. The Mitsubishi HS-U448 has its motor underneath the machine. You don't have to remove the top cover at all. Just remove the bottom plate and spin the motor (the correct direction) to completely eject the tape.
Dec 23, 2010 | Mitsubishi HS-U448 VCR
Mitsubishi HS-U57 vcr front display gets very dim!
Your front display is worn out, it has gotten gassy. Therefore the luminance level is low & the part is no longer available.
Nov 07, 2009 | Mitsubishi HS-U577 VCR
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
When I put a tape in my vcr it spits it back out...
this sounds like a cleaning and tape carriage alignment is needed, that not too hard to do if you tinker.Service on this is not too much at electronic or tv repair
Jan 26, 2009 | Mitsubishi HS-U545 VHS VCR
VCR functions do not work (play, record, ...)
Sounds like the idler assembly isnt working. Without this assembly, the system cannot get the tape to actually move, and most systems will shut down if the tape isnt moving to prevent damage to the tape. In truth, this can be a complicatred repair, requiring the machine to be taken apart quite a bit. I would suggest taking this kind of a problem to a repair shop, but with the cost of simple VCR's coming down constantly, and the upcoming switch to DTV making the machines tuner obsolete, it would probably be more economical to just replace the machine.
Feb 15, 2007 | Mitsubishi HS-U110 VHS VCR
Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Dec 19, 2006 | Mitsubishi HS-U760 S-VHS VCR
Mitsubishi HS-U748 S-VHS VCR Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
