I am looking to buy a inexpensive laser printer, black only. to run a high volume
    Master:
  • 518 Answers
Here is a wide variety of them from a reputable site. If you're wanting something that will do high volume and last, I would recommend at least a midrange unit.
Hope that helped...
Geno
Posted on Apr 04, 2008
SOURCE:
Faint black print
Non manufacturer ink Is inexpensive for a reason, they skimp on the ink. Bite-the-bullet and buy Name brand ink. I know from experence.
Nov 15, 2012 | Dell 3110cn Laser Printer
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
HOW DO I SET UP TO ONLY PRINT BLACK.
Buy a monochrome laser machine. There are no ink printers that only ever print black. Laser machines are 1/2 the cost per page, never clog, and run forever.
Sep 27, 2010 | Office Equipment & Supplies
How can i make this printer just print in black ink only ?
You can't, HP and all the other printer manufacturers have designed the new ink printers to always mix a little color with the black. This is why if you you've noticed when you run out of black ink the text starts looking funny colors. If you would like to only print in black we recommend purchasing a small monochrome laser printer. The Brother HL-2140 is a nice, economical, and inexpensive unit for this purpose.
Feb 02, 2010 | HP Deskjet F340 All-In-One Printer
I cannot print black when the color cartridges are empty. MOdel mfc665cw
Don't you see the logic? Brother wants you to spend money by buying color cartridges. And also, most printers are also using colors to make the prints darker.
Jan 09, 2010 | Brother Office Equipment & Supplies
Can I run a laser printer on a laptop?
Laptops will run a printer just as well as a PC
Dec 27, 2009 | HP Computers & Internet
When we print manually the whole page comes out completly black.
edithvenzor:
Try replacing the toner cartridge first, then proceed with the other items.
Thank you and let me know what happens:
Binary Bob
Problem
Cause
Solution
How common*
Comments
BLACK PAGES
DC Controller PCA is defective. If the DC Controller turns on the laser beam continuously,
the entire surface of the Photosensitive drum is neutralized causing a completely black page
Replace the DC Controller PCA
10
BLACK PAGES
Defective toner cartridge
Replace the toner cartridge
9
BLACK PAGES
High voltage contact springs are dirty or defective. The high voltage contacts are mounted on
the High Voltage Power Supply PCA and protrude into the toner cartridge cavity
Inspect and clean the high voltage contacts. If damaged, replace the High Voltage Power Supply PCA.
BLACK PAGES
High voltage power supply circuit is defective (not supplying the correct negative voltage)
Replace the High Voltage Power Supply PCA
10
some printers have the high voltage power supply on the DC controller.
BLACK PAGES
Laser/Scanner Assembly is faulty (turning laser on continuously)
Replace the Laser/Scanner Assembly
5
BLACK PAGES
Light is leaking into the printer
Make sure that all covers are in place
possible, but not likely
Nov 30, 2008 | Office Equipment & Supplies
Messy prints
not a solution but i have the same problem, found that buying bottles of fuser oil and adding it regularly to orange foam rollers found under fuser oil unit helps although 1st page printed will be covered in oil. also i have cut holes in top of fuser oil unit so can keep a high level of oil. i have 5 of these printers all with the same problem.in my search for a solution came across this, rings true to me. http://www.dec.com/sbso/expert/competitive_ricoh_reliability.html
Nov 08, 2007 | Ricoh Aficio CL7000 Laser Printer
Open Questions:
jasbo
jasbo
Ekse
Marvin
Marvin
