Question about Canon Rebel XT / EOS 350D Digital Camera
Canon 20D error 99 shutter stuck
As soon as you turn the camera on the shutter starts clicking and won't stop... the button is NOT depressed though...
  • 1 more comment
  • Anonymous May 15, 2008
    Exactly the same problem with my 20D tried everything removing both batteries etc still nothing works.
  • mrkevrob May 27, 2008
    canon 20D- error 99. shutter clicks repeatedly. both batteries and card have been removed.
  • Stoney717 Jun 15, 2008
    is this site some kind of scam?... your just posting other posts with people having the same problem as mine, with no answers... and if I want an answer I have to pay???
    LOOSE THIS EMAIL ADDRESS!!!!! You people are a scam and about to become SPAM.....
Canon digital slr cameras have a shutter life of about 60,000 shots, then the shutters weaken and freeze up, you then have to pay about $250 for reapirs
Posted on Sep 01, 2008
I hust send it to repair lest wait...
Posted on Aug 28, 2008
Chuck it in the bin!
Posted on Aug 16, 2008
Exactly same problem, shutter clicks until battery removed. Power may be on or off.
Posted on Jun 15, 2008
Canon eos 20d error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 20d service manual link:
http://goo.gl/YtVLQR
it will help you to save a lot of money
Hope it helps, Thanks
Aug 07, 2011 | Canon EOS-20D Digital Camera
Canon EOS Digital Rebel XTI 400D Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99 camera is totally charges, acts dead, keep flashing Err CF, I try to format, it...
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Aug 31, 2008 | Canon EOS-20D Body only Digital Camera
Canon 20D gone shutter crazy , clicking away on its own error code 99
The Canon 20 D is a fantastic camera but the weak point is the shutter it last about 70 to 80,000 actuation then causes a bunch of problems. In Canada it cost about $180.00 including the shipping to the repair depot to get it fixed.
Jun 21, 2010 | Canon EOS-20D Digital Camera with 55-200mm...
Have a canon rebel EOS 20D that registers an error 99 after I take one frame and then won't allow another one to be taken until I turn camera on then off again. Does this require factory repair or is there...
Hi LLFraserny,
You can probably try to isolate the error 99 first.
To isolate the cause of the issue, do the following:
3. Allow the camera to sit without power for approximately 30 minutes.
Does the “ERR 99′ message appear? If it does, then the camera will need to be serviced. If the message does not appear, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
One last item to check before sending camera to Canon service is the alignment of the shutter. Life the mirror and visually inspect the shutter curtain. If each segment is not completely straight, touch it lightly with your blower bristles and try to pop it back into alignment.
Hope this helps,
Andrew
Apr 09, 2010 | Canon Photography
Canon EOS 20D shutter error
Hello - I figured it out. I had the exact same problem. The shutter failed and it had to be fixed by Canon. Apparently that happens after the shutter fires so many times (like a click-count on a printer). I just got my camera back and it's doing awesome now.
Feb 19, 2009 | Canon EOS-20D Digital Camera
My canon 20d stopped taking photos for no aparant reason. Kept getting error 99 and when I re insert the battery it starts clicking on it's own whether turned on or not. I sent it to Canon repair who...
If two cameras are doing it, I would suggest the contacts on your lens are dirty.
Try the following diagnosis steps for solving ERR 99 issues : -
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My Canon 20D suddenly started saying "Error 99" and it won't take any pictures. What should I do?
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
Aug 06, 2008 | Cameras
Error in body
Remove lens, CF card, and battery. Leave in a dry and slightly warm place for 24 hours. Clean lens contacts with a cloth or cue tip and eclipse/alcohol.
If the camera doesn't turn on after this, even without CF card and lens attached, then it needs to go to a Canon service centre. Don't tell them you got it wet, and maybe it will get repaired FOC.
Jul 07, 2008 | Canon EOS-20D Body only Digital Camera
Error 99
camera body.
Jun 28, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Error 99
I get error 99 sometimes on my 20 D but it?s usually to do with a lens that is attached. Sigma lens have been known to cause error's. If it's not that or dirty contact on the lens then it could be a more serious problem. I would at least check it out with a canon dealer/repair centre.
Sep 14, 2005 | Canon EOS-10D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
1,250 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
