Audio occasionally dissapears for 1 second and returns (as if I were changing audio source)when playing music from coax imput1
    Genius:
  • 1,550 Answers
Checa el cable coaxial puede estarse quebrando.
Posted on Apr 04, 2008
No sound from deck
Are the speakers connected directly to the JVC? If so, all four speakers going quiet could be bad soldering on the radio. If the speakers are not connected to the radio, then check the blue/white wire that turns on the internal amplifier.
Aug 06, 2013 | JVC KD-G340 Car CD/ MP3 Player
Tip
Adding your own music to Super Smash Bros. Brawl
To play your own music on super smash bros brawl, follow these 10 simple steps, but first, this is what you need: an audio source (ipod mp3 player, etc.), SSBB, a wii, and AV cables (red, white, yellow on one side and silver on the other that can be inserted into your audio source
1 take an audio source (mp3 player, ipod, etc.) and plug in the AV cables.
2 Start super smash bros. brawl.
3 go to options
4 go to sound
5 set music off and sound max
6 set up your game normally
7 move your cursor over the stage you want to play.
8 remove the RED cable of your wii and insert the RED AV cable connected to your audio source
9 Chose your song
10 start your game!
on Apr 05, 2009 | Nintendo Super Smash Bros. Brawl for Wii
How do i connect my lg42lh2000 to my lg ht302 receiver so that the sound from the tv can be heard through the recivers speekers
you will need:
rf modulator.
coax cable.
video cables.
run audio cables from yourmusic source to the reciever that should work but if your music source is away from the reciever then get an rf modulator and put your music source by your reciever and the put thevideo cable from your music source to the rf modulator and tthenrun a coax cable to the tv and then run the audio cables from the music source to the input on the reciever. for example i have my direct tv box sound running through my reciever and speakers, and to have musicfrom the direct tv box going through my speakers i put the audio cables from my direct tv box into the audio input on the reciever and then the video cable into the rf modulator and then from the rf modulator i ran a coax cable to my tv then i had my sound from the direct tv box going through my reciever and the video on the tv.
plz tell me if this works :)\
Aug 05, 2013 | Audio Players & Recorders
When i plug my iphone 3gs into the ilive itp100b i try to play my pandora music app and the music plays for 2 seconds and then stops. the music on the app continues to play on the phone but the ilive isnt...
I have this exact same problem... audio I loaded on through itunes play perfectly... songs, audiobooks, podcasts, etc, as well as input from my TV and the build in FM radio, but anytime you try to use any 3rd party radio app on the iphone, you get like 2 seconds of audio and then nothing, and the app usually has some text that says, "No Volume Available".
From research, it seems that the iLive company is to blame as they did not update the firmware to work correctly with iOS 4, so it is their problem and not the iPhone. I am returning my device and getting another brand that supports iOS 4
Dec 21, 2010 | Audio Players & Recorders
On hold device
Start by looking at the system. It's pretty tough to miss the two jacks labeled MUSIC and PA.
They take a 1/8" (3.5mm) mono jack, so you can come out of your MOH device with an RCA to 1/8" or 1/8" to 1/8" cord. Your local Rat Shack should have the cables.
Carl
Feb 26, 2009 | TalkSwitch CT.TS001.124001.US...
Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Jan 14, 2009 | Onkyo TX-SR606 Receiver
CD volume
Select the source to adjust
Press the [SRC] button.
2 Enter Audio Control mode
Press the Control knob.
3 Select the Audio item to adjust
4 Adjust the Audio item
Turn the Control knob.
S Exit Audio Control mode
Press any button.
Press a button other than the Control knob or ...
button.
1 Select the Basic Audio item
For how to select Basic Audio items, see <Audio
Control> (page 6).
2 Enter Detail adjustment mode of Audio
Control
Press the Control knob for at least 1 second.
3 Select the Detail Audio item to adjust
4 Adjust the Detail Audio item
S Exit the Detail Audio Control mode
• When you set the Bass Extend to ON, low frequency
response is extended by 20%.
• You can exit the Audio Control mode at anytime by
pressing any button except for Control knob or ~
button.
http://akamaipix.crutchfield.com/Manuals/113/113MP338.PDF
page 6 and 7
May 06, 2008 | Car Audio & Video
Venturer AVR2000, home theatre system
I have same system and had same problem until I connected digital audio coax to receiver from digital source.(orange port). Also try making the center front speaker much louder volume setting than all other speakers. hope it helps.
Jan 27, 2008 | Venturer (1012827) System
19 people viewed this question
 Grubhead
Grubhead
