Question about The Box Active Noice Cancelling Headphones
I HAVE A DIGITAL RECIEVE CALLED THE BOX IT HAS BEEN UPDATING ALL DAY AND I CAN ONLY GET 4 CHANNELS ID THERE A CODE I CAN RESET MY BOX WITH PLZ.
PLZ HELP
  • 3 more comments
  • Lisaro Apr 04, 2008
    i have a digital reciever called the box, it has been updating all day. normally it goes up to 1000% but when it gets to 220 or sometimes 250 it starts agin is there a code i can put in to restart it plz?
  • racer 1 Apr 13, 2008
    i have been trying update my (the box) to watch footy but is continualy up dating can anybody help
  • tipponeill Dec 18, 2008
    lost most channels did frequency change fix when i go to parental control to press info on remote, screen wont open.
  • Anonymous Jan 21, 2009
    i have the box 3 and cant get it to work its new but i dont have the instructions?
  • patrickmaher Apr 04, 2009
    buxx
  • 4 Answers
The new key is cd 11 58 05 ee 96 e7 f3 you need to enter this code in the secret menu to access that press menu on the control then key in 1570 then go to nav option then your on the page it should have ntl 5401 then 00 underneath then you write it under that
Posted on Nov 30, 2008
Posted on Apr 09, 2008
Have a cable box on 19inch lcd sansui, and can't recieve my digital channels?
Is it supported by the TV? Are you licensed to receive the Digital channels, i.e., is it a payable channel?
Aug 16, 2012 | Goodmans GTVL19W17HDF 19 in. LCD TV
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
Our cable company has upgraded to digital channels. This tv has the right equipment in it and should find the digital channels but doesn't. When I first did a digital channel search it grouped channels...
the cable company switched to digital just like everyone else, but that should not effect your viewing, they convert the channels back to basic cable so you can see the without having to do anything. If you want to watch "over the air" digital tv you need an outside antenna and television that can recieve digital signals, or put a digital convertor box on your set, but none of this makes any sense if you have cable because you are already getting the same channels over the cable.
Mar 19, 2011 | Televison & Video
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
Channels lost on starview box
Yeah i had the same problem with starview 4. i upgraded the firmware and still no good. i then by accident set the default key. it worked. i'm not sure if it will work for u.
Aug 30, 2009 | StarTech.com StarView SV211K 2-port KVM...
Certain channels says need code updating
hi,
some channel says code update, what can i do.
Apr 15, 2009 | Televison & Video
Codes don't work
once you are into the menu screens the Nagravision screen will come up look down the list and make sure your EMU is set to ON.?
In the code screens make sure the provider ID is set to your provider?.
when you change the codes store each code entered then exit out .
hope this is helpful to you.
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Euro-vox max 2006
Re euro-vox problem
I tried the bigMaq toolbar and entered the latest keys and now all channels are back.
Thanks Guys
Apr 09, 2008 | Audio Players & Recorders
467 people viewed this question
Top The Box Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a The Box Audio Player and Recorder Expert? Answer questions, earn points and help others
