Go into your Audio menu on the TV and make sure the TV speaker are set to “ON”.
If the external speakers work when connected to the TV and the TV’s internal speakers don’t work when you remove the external speaker’s plug from the TV, then you will need to replace the main board.
The main board has all the function for the audio for the internal speakers. This was a known issue for some of the LG TV’s. So if you call LG about this issue, LG may fix it under a warranty.
Good luck.
Make sure the tv speakers are turned on in the audio menu
if they are, suspect a bad main board (all audio circuitry is on the main board)
