Question about Ricoh 6513 Copier
Ricoh 6513 error code PM CAll
When I switch on Copier, I get this
PM CALL. Call for Service
What does PM mean the copier is still working at this time
    Scholar:
  • 141 Answers
Preventive maintenance.....
It's for a clean up, and sometime there's some parts to replace...
Posted on Apr 05, 2008
SOURCE:
When I switch on my photocopier machine it display "PM CALL" What does it mean
It means that the copier is due for it's PM or Preventative Maintenance. All copiers have a PM schedule so that every so many copies certain parts called "consumables" come due for replacement. These are things like Drum, Developer, Fusing Rollers, Etc. If you really depend on your copier and finances are not an issue I would call your servicing company and have them come perform what ever maintenance is required. If this is not the case there there is no harm in continuing to use the machine. Worst case scenario is that you may see a drop off over time in copy quality or you may experience more jamming.
Good Luck and Thank You for using Fixya.
Sep 18, 2010 | Office Equipment & Supplies
What does the red triangle mean on the copier please
It helps to know the make and model. Also, is the copier still working? If it is still working it may just be a P.M. counter.
Jul 23, 2010 | Office Equipment & Supplies
How to remove service man from copier sharp ar5320
hi the service man means yours copier have complet the pm cycle if u dont want to replace drum and devolper u can clear the pm counter with sim 24-4
thanks
May 12, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
My copies are blank. I replaced tonor, but still no ink.
Hello sir; I believe it is time for PM service, that means you need to replace drum, blade, developer, etc.
May 14, 2009 | Minolta Office Equipment & Supplies
Need service codes for this model
By default, after 74000 of PM counter, it will appear.
U can clear it if the machine is working fine.
Reset PM counter
08-252, set the value to '0'
To disable the PM counter,
08-212, set the value to '0'
May 06, 2009 | Toshiba e-STUDIO 282 Black and White...
PITNEY BOWES C180 COPIER
Contact OCE to find a dealer in your area. There the ones handling service on Pitney Bowes copiers.
Jul 29, 2008 | Pitney Bowes C180 Copier
Toshiba studio 35
switch off...hold down 0 + 8 keys,
switch on holding keys for 5-10 secs then let go.
service mode...
punch in 251 then print key should show pm set figure,punch in say / add 20,000 on to figure then press set in the display.
switch off then on should have cancelled prevent maintenance.
Jul 16, 2008 | Office Equipment & Supplies
Cannot get the machine out of PM Maintenance mode
to reset PM counter : Hold down 0+8 together, turn on power switch, enter number (252), press (0) key, press ( enter) on screen, Shut down then turn machine on again.
Jul 10, 2008 | Toshiba e-Studio 350 Copier
Minolta ep4000 cs pro imaging unit
Ask you service guy if he can or knows how to rebiuld your IU / drum unit. You can still get parts for that copier you probly need a new OPC drum and cleaning blade and a developer change. I belive they should last for 80k copies more or less. Are you getting black lines and bad copy quility? If not you may just have the PM / IU light ON or it is asking for a PM? It is just a counter in the copier that say's it time to replace the PM parts. They may have been replaced , but the counter was not reset. On a final note, this is one model in a long line of the same machines with alot of the same parts. I don't think it is hard to find these parts. You can buy them on line.. Under copier part....
Order the parts your self and save money and have them install them... Good Luck
Apr 03, 2008 | Minolta EP4000/5000 CS/PRO Copier
Ricoh 6513 Copier Logo
1,065 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
