Question about GE Microwave Ovens
Purchased an over the counter microwave oven, model JVM1540 DM2WW. It only seems to have 30 seconds as a minimum setting How can set the time at 10 sec. or less? (short of chosing "add 30 sec" and stopping it.) This assistance should be at no cost.
Went to the store where I bought it, and talked with a sales rep. in the appliance dept.
After paying $ 198 for the microwave and...$ 159 to have it installed, I was not about giving $ 9.99 more to answer a simple question.
Posted on Apr 06, 2008
How can I cook for 20 seconds in SANYO MICROWAVE 1250W EM-S2587V
Go to www.sanyo.com contact customer support and the technical department to see it they can offer a solution to set it below the 30 seconds.
May 28, 2012 | Sanyo Microwave Ovens
The GE Spacemaker Microwave Oven model JVM1540 noise
The problem is more than likely the magnetron when it is running.
Mar 13, 2012 | GE Spacemaker JVM1540 Microwave Oven
I have never used the power feature and now I need to and cant find manual. How does the power feature work. I need to operate the microwave on medium power for one minute.
1 Use the number buttons to set a cooking
time. You can set a time from one second to
99 minutes, 99 seconds. To set a time over
one minute, enter the seconds too. For
example, to set 20 minutes, enter 2, 0, 0, 0 .
2 If you want to set the power level to
something other than High, press the Power
Level button, then use the number buttons
to enter a power level.
Power Levels:
Level Cooking PL
1Warm10
2Low20
3 Defrost 30
4Medium Low40
5Medium50
6 Simmer 60
7 Medium High 70
8 Reheat 80
9 Saute 90
10 High Hi
Hope that helps.
Mar 01, 2011 | Emerson MW8107WA Microwave Oven
I have a 15 year old Toshiba microwave which I may need to replace. It can be set to cook in single seconds (eg for 23 or 38 seconds) a facility I find essential. Many new microwaves it seems can only be...
I believe the dial on Hobart microwaves allows you to manually enter any amount of time by spinning the dial for the desired time, and programmable buttons to save the time settings. HL1600 is 1.5 cubic foot, 44 liters
Feb 11, 2010 | LG LMVM1935 Convection/Microwave Oven
JVM1540 Above the oven microwave is not heating anymore
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfgf
Dec 15, 2009 | GE Spacemaker JVM1540 Microwave Oven
Instruction Manual for Sharp Microwave Oven
I can explain that. You enter the power level you want from 0 to high(10) the number corresponds to a percentage of time the cook cycle is ON. 5 being 50%, for each minute of cook time programmed the magnatron will be on 30 seconds and off 30 seconds. You can program anything from 10% to 90% in place of the high or "always on" setting. Eric
Sep 06, 2009 | Microwave Ovens
GE JVM1540 keypad only works for some buttons
Membrane keypads are not very durable, and do fail after a relatively short time.
The only method is to replace them as a spare part.
Aug 20, 2009 | GE Spacemaker JVM1540 Microwave Oven
We have just purchased a GE microwave oven, model JES1358WL. the light is on, the turntable turning, the control panel shows cooking and seconds counting down when attempting to heat cup of water. it is...
First: never attempt heating pure water in a microwave, that is dangerous.
Ensure the oven is not set to the minimum power, otherwise the heating will be minimal.
Try heating some food at maximum power for two or three minutes, if it does not heat, take it back to the shop.
About water in the microwave, see here:
Microwaved Water - A MUST see
Superheating of water
Oct 16, 2008 | Microwave Ovens
Gap between cabinet and top of microwave oven
eastlake...only if you think so. Most of these units use a submounting bracket set and then you hook your oven to it. This is a rather nasty installation...I've done several. If it's sturdy, you may just want to put in a filler piece.
Dec 10, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
55 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
