CAN YOU MIX THESE TOGETHER ON THE MOTHER BOARD KV200/KV200R CENTON 256MBPC133 & VALUE SELECT CORSAIR VS256MB333
    Scholar:
  • 67 Answers
What on earth are you saying? Give us a hint.
Posted on Apr 04, 2008
SOURCE:
RAM Problem in intel D915GLVG mainboard
Most likely the pc400 hynix is incompatible with the mother board, or with the memory you are leaving in place. Try using just the pc400 sticks, if you still get system beeps then you are using incompatible memory. You should go to centon, or other memory manufactures wesbsite and look up what is compatible with the mother board and get that memory for the system. My bet is going to be pc3200 memory.
Hope this helps
Jan 25, 2012 | Intel D915GLVG Motherboard
Will a Corsair cx430 power pack work with this mother board pm8m3-v
It will work with the base motherboard. If you have a mid-to-high end graphics card, however, you will need a higher-rated power supply. If you're not using a graphics card, then the Corsair should work great.
Hope that was helpful. Good luck!
Mar 04, 2011 | MSI PM8M3-V Motherboard
I CANNOT LOAD WIN7 I cannot get my system to boot from a CD disk (Win 7 Ultimate) I set the BIOS to boot from a CD device - the priority is set for CD first. All other values are default. In...
try to reset bios if does't work try using a usb dvd drive (external dvd drive) remember you do not will be able to read a dvd CD(WINDOWS 7 CD) using a cd burner.
you will need a dvd drive.
Feb 07, 2011 | ASUS Computers & Internet
Sir, I am using Intel Mother Board D845EPI , I miss my mother board CD So kindly send me the BIOS & DRIVERS of the Mother board. Thanking You REJI MATHEW my EMAIL-...
Normal 0
You can download the motherboard drivers from Intel WEB site. Select your model motherboard/device, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system.
Please click on this link and select your model motherboard : -
http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Oct 09, 2010 | Computers & Internet
Iwikk kv200r motherboard. connectors
To the corresponding button and LED from the case.
Dec 21, 2009 | Computers & Internet
I have a abit v17 mobo want to get max ram (2gb) bought kingston value ram from kingston rep said it would work. also have corsair matched memory also was told by rep that it would work. I plug them in and...
Your motherboard supports DDR SDRam I assume the ram sticks you bought fit in the socket correctly and are the right way round?
Try the computer with each ram stick seperately. Just because ram is new doesnt mean its not defective.
What configurations do you have?
Are you using two corsair sticks or two kingston or a mix of both and what models are they?
Jun 19, 2009 | Computers & Internet
MOTHER BOARD
I need a diagram to connect the Front Panel Connections for a Uwave2 kv216A7404 motherboard.
Thanks, Michael
Oct 07, 2008 | Computers & Internet
Unable to boot up
The problem is of the display side so if possible connect the pci
display card or can repaire the mother board, If not then only solution is to change the mother board.
Thanks
Sep 08, 2008 | ASUS P5B-E Motherboard
ASUS A8N-SLI memory issues
imondeau, do you still have you're manual for the ASUS A8N-SLI Premium? Please turn to page 2-12 & 2-13.
Need the manual? Click the link below & download it.
http://support.asus.com/download/download.aspx?modelname=A8N-SLI%20Premium&SLanguage=en-us
The QVL; Qualified Venders List, shows all the tested memory for this board. Edge memory is not supported. This is why the Edge memory only runs by it's self. Once you add the corsair memory they clash because they are not compatible working together in this Asus board. Both sets of memory could work in another board. (Maybe)! What is also needed is if the corsair & edge DIMMs are SS = Single sided or DS = Double sided. How many chips on the corsair? How many chips on the Edge?
They must have the same total chips each each DIMM.
Edge does not sell memory compatible for the
Asus A8N-SLI Premium.
See this for you're self. Click on this link:
http://www.edgetechcorp.com/memory/
Mike
Jun 17, 2008 | ASUS A8N-SLI Premium Motherboard
Open Questions:
HOW TO CONTACT AOL EMAIL SUPPORT 18OO8O31O69 There are two circumstances that can cause someone to want to change his/her AOL password: 1 forgetting the AOL password and needing to recover it and 2 to change the AOL password. The latter can be because the AOL password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's AOL password at least once in a month. Contact Aol Mail Password Reset. For your convenience to contact Aol Mail Password Reset We have provided all possible information of Aol Mail Password Reset. You can contact Aol Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an AOL Password The following steps show in detail how to change an AOL password when the current password is known: Sign into the AOL Mail Account from AOL Do you want to recover/reset your AOL email password? So you'll be do the some steps to recover your AOL password. We'll help you to fix your problem and we'll guiding the some steps to recover your AOL password. Follow and do the below steps to recover your AOL email password- Go to the AOL - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your AOL mail message on your Gmail account. AOL is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While AOL's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, AOL has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your AOL password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your AOL password.
Oct 22, 2019 | AOL Computers & Internet
Computers & Internet Logo
24 people viewed this question
Ekse
Marvin
Marvin
