How to disconnect external hard drive from my laptop
  • 1,944 Answers
If it's connected through USB, then you can remove it like any removable storage (like USB flash drives).
Posted on Apr 04, 2008
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
Blank/black screen when i turn on the laptop
Please try the basic troubleshooting steps to resolved the issue:
- Disconnect all external device (example: USB Flash Drive, Printer, external hard drive, etc.) - Turn off the computer by pressing and holding the power button until all lights turned off. - Disconnect the ac adapter from your computer. - Remove the battery, wait for 10 seconds, then connect the battery back. - Plug in the ac adapter. - Turn on the computer.
Hope that helps.
Apr 17, 2011 | Dell Vostro 1510 Laptop
I recently purchased a new Cavalry external hard drive (500gb, CAUG25500), and had been using it on my Thinkpad laptop with XP. It was working fine, no problems. Before a trip I was going on, I wanted to...
1. This could be due to several things.
a. The power supply for the external drive is not working properly
b. A broken power supply connector.
c. The USB drive was disconnected improperly > that is not disconnected safely in Windows
d. The external drive controller in the USB case is defective. A new case is needed.
Mar 16, 2011 | Cavalry Storage Cavalry CAUG 500GB USB 2.0...
Suddenly, my transcend external hard disk is not being recognized by my laptop. I had been using it since more than a year on the same laptop same port.
Several things could be happening here:
1. your electronic controller in the hard case has failed.
2. you didn't properly disconnect the external hard drive in Windows > with the
"Safely Remove Hard ware and eject Media" in the task bar.
3. if you have a power supply to the USB drive it may have a damaged power connector or not supply proper power to the device.
Mar 16, 2011 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Where is info stored on a external hard drive
An external data-storage device has a few parts:
* a USB cable
* an enclosure
* a disk-drive, exactly as used inside a desktop or a laptop
* a USB-to-disk-drive adapter
So, if you open the enclosure, you can see an "internal" disk-drive.
You could even disconnect the disk-drive, and then connect a much-larger disk-drive,
in order to increase the capacity of the device (and to replace an out-of-warranty disk-drive
by a new in-warranty disk-drive).
Oct 24, 2010 | Maxtor Hard Drive
G60-230US PC Notebook died. It reads: "No bootable device--insert boot disk and press any key" on startup. startup test failed: "there is no hard disk."
It means that your notebook is not able to detect any hard drives or a bootable drive
also plz check if there are any cd/dvd or any external devices like flash drives or external hard drives connected to the nb.. If so disconnect all the external devices and try to boot up ..
If it does'nt work go to the bios screen by continiously tapping F10 or F2 or DEL key as soon as you turn on the nb and check if the hard drive is detected or not.. if its not reset the hard drive and retry.. If the hard drive is detected run a hard drive self test if it fails.. replace the drive if it passes run system recovery
Hope it works
All the best !!!
May 06, 2010 | HP G60-230US Notebook
I got this hard drive so I could free space on my laptop. I was able to transfer all my picture files onto it. I checked to see if the files had gone on it okay and they did because the capacity of the...
Just because you transferred it to your external hard drive. You will still have the files on your internal HD. You will need to delete the files off your internal HD and they will still be on your External HD. I had to do this with mine and other clients.
Jan 05, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Accidentally disconnected external HD while moving files
have the files been deleted from the laptop? if not i would simply do a fresh format on the external and re migrate data. if they are then you can get software such as undelete or recover my files to restore your deleted data off of your laptop drive.
Dec 09, 2009 | Western Digital My Book Essential 1TB...
How do I completely reset my external hard drive
1. You need to check how much free disk space is available on your laptop.
2. You need to check what duplicated files you have on both the laptop and the external hard drive and which is the latest version.
3. You need to decide to move the latest versions of the data files from the external hard drive to the laptop. This automatically delete these from the external hard drive. The older versions on the external hard drive can be deleted.
4. Now you need to check how much data is stored on your external hard drive.
5. If the amount of data stored on the external hard drive exceeds the available disk space on the laptop, then you cannot copy these files to the laptop.
6. If you have sufficient disk space on the laptop you can copy the data from the external hard drive to the laptop. I suggest you make a folder to copy this data to it.
You can now delete all the data from the external hard drive or you can format the external hard drive to make a clean external hard drive.
Oct 01, 2009 | Western Digital WD Passport 250GB Portable...
Laptop freezes when connected to external hd
I am assuming the external is connected while booting up, if so then the laptop may be seeing this unit as a bootable drive. You would need to enter into the BIOS of the laptop and change or make sure the external drive (i.e usb connection) is disabled. Save and reboot with the ext disconnected, log into windows and when it has finished loading, connect ext drive. I hope this helps.
Jul 01, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
