Question about Microsoft Xbox 360 Console
E74 error message
I get 1 red light in the bottom right corner on my 360. is this definitely to do with the AV cable?
    Problem Solver:
  • 3 Answers
I had the same problem,they say it might have to do with the power supply or the cold solders inside the xbox not connecting the chips on the board.If it's under warranty send it back.I on the other hand i cracked mine open (void warranty),so i tried the towel trick(wrapping your xbox with 2-3 towel and running it for 15 minutes then cooling down for another 10 mins)worked for me.Although i have to do this almost every other day.Good luck!!
Posted on Apr 05, 2008
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
My xbox crashes, then one red light on the bottom right hand corner of the controller port and it flashes
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Sep 23, 2009 | Microsoft Xbox 360 Console
Xbox360 e74 error
Section 4 is flashing red
- Hardware Failure
Jun 06, 2009 | Microsoft Xbox 360 Console
ERROR 74 on xbox 360
It's a AV cable error. Try the switch on your cable. Move the switch while the console is on then turn it off and back on again. If this doesn't work then do the xclamp fix. This fix is not just for the 3 red rings.
Jun 04, 2009 | Microsoft Xbox 360 Console
Red flashing lights
This issue may occur for one of the following reasons: • The audio-visual (AV) cable is not connected correctly or is not plugged in to your Xbox 360 console. • The console is not detecting the cable.This issue does not occur if the AV cable is plugged incorrectly into a television, a stereo, or a VCR.
Note This issue occurs only on Xbox 360 consoles that do not have a High Definition Multimedia Interface (HDMI) AV port.
Apr 11, 2009 | Microsoft Xbox 360 Console
Turned on xbox 360 got a black screen saying system error and E 74 at the bottom of the screen and theres 1 red light on bottom right of power button
Mar 06, 2009 | Microsoft Xbox 360 Console
My xbox 360 has a red light at the bottom right hand corner with error code E 74 what does this mean and how can i fix this?
make sure that the hard drive and av cable are completely plugged in and then try to turn it on and make sure you let it cool overnight
please rate well
Jan 06, 2009 | Microsoft Xbox 360 Console
On my xbox 360 one red light appears in the bottom right hand corner and on the screen it shows e 74 error
this is a scaler chip problem, a problem with the av cables, or a GPU issue. try borrowing someones av cables, if not, you can try baking the system.
Nov 18, 2008 | Microsoft Xbox 360 Console
One red light bottom right hand corner
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jul 22, 2008 | Microsoft Xbox 360 Console
E 74
E74 is an error with your AV cable and or your GPU / Scaler chip. If you can swap out your AV cable to see if that works if not you will have to contact MS, as there is no quick fix for this error if your cables dont work. Hope this helps.
Jan 07, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
