I have a Brother DCP120C Multi Function printer and am using Windows Server 2003 Datacenter x64 edition as my OS. Which printer driver can I use to install my printer (I'm resigned to losing the scanner function)as Brother are too cowardly to support printing on Server 2003? Please help me before I **** kill myself! Cheers, jasperfish, Lord of Atlantis.
    Master:
  • 518 Answers
Hi Lord of Atlantis, don't kill yourself yet, I see 2003 drivers that were released 03/19/2008. You can download them HERE .
Hope that fixed ya...
Geno
Posted on Apr 04, 2008
SOURCE:
LaserJet CM1017 MFP scanning issues i need windows 7 driver this printer everything is well but not working scaner so plz solve my issued
Improve the Fixya.com experience for everyone by voting!
You are in luck because HP just released on 7/5/2011 a new driver for your CM1010 printer. The following is the description with the download link following.
Type: Driver - Documentation Version: N/A (5 Jul 2011) Operating System(s): Microsoft Windows 7 (32-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Server 2003, Microsoft Windows Server 2003 64-Bit Edition, Microsoft Windows Server 2008 W32, Microsoft Windows Server 2008 x64, Microsoft Windows Vista, Microsoft Windows Vista (64-bit), Microsoft Windows XP, Microsoft Windows XP x64 File name: HP_UPD_direct_IP_Printing.pdf
Download this driver by clicking on the following link: CLICK HERE
All the best
Ben
Jul 11, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
Tip
Mamimum RAM for User @ 3GB using boot.ini switch on 4GB Physical RAM
The DOS will always take a percentage of the physical RAM on the motherboard leaving the rest for the User. By default the Windows Operating System will use 50% of the physical RAM installed on the motherboard leaving the user the remaining 50% this can be changed using a switch in the boot.ini file
The /3GB was originally meant to be used in systems that have 3GB or more of RAM something that is no longer quite as rare as it used to be Windows XP SP3 will support upto 4GB although on a 32bit (x86) version of Windows will acually see 3.25gb that is the limitation.
However, even if you don't have 3 GB or more of memory, you can still use the /3GB switch. the switch can have any value between 2048 (2 GB) and 3072 (3 GB) megabytes. It needs to be expressed in decimal notation.
The /3GB switch applies to 32-bit systems only (x86).
Example with Windows XP SP3 Home Edition with the recovery console installed this gives you the option of default 50-50% split or the 3GB switch 75-25% split.
The /noexecute parameter enables, disables, and configures Data Execution Prevention (DEP), a set of hardware and software technologies designed to prevent harmful code from running in protected memory locations using the optin switch enables DEP only for operating system components, including the Windows kernel and drivers. Administrators can enable DEP on selected executable files by using the Application Compatibility Toolkit (ACT).
The /burnmemory parameter specifies the amount of memory, in megabytes, that Windows cannot use in this example, /burnmemory=128 will reduce the physical RAM memory that is available to Windows by 128 MB.
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition 3GB Switch" /noexecute=optin /3GB /fastdetect
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition " /noexecute=optin /burnmemory=128 /fastdetect
C:CMDCONSBOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
Check out the noexecute and the 3GB switch plus all available boot.ini switches HERE
I suggest that you use AnalogX MaxMem it is a realtime physical memory management program that automatically ensures that you always have as much physical memory available as possible used with the 3GB switch you should never have memory issues ever again.
on Mar 14, 2010 | Microsoft Windows XP Home Edition for PC
I cannot install windows 7,no disk seen are there drivers for raid smart array 5I for windows 7? DL 740 G1 , 8 x 2700Mhz+40GB ram , 4 x 73gb Raid 5
Not quite sure what your problem is but I would recommend getting Windows Server for a server like this. The HP site recommends the following OSes: Microsoft Windows 2000,
Microsoft Windows Server 2003 (Standard, Enterprise, and Datacenter) ,
LINUX (Red Hat, SuSE) or Microsoft Windows 2000 Datacenter Edition. It is unlikely Windows 7 will install on this 5 year old server.
Jun 06, 2011 | HP Compaq ProLiant DL740 Server
WINDOWS 7 COMPATIBLE?
Yes, just use Windows 7 Update function to install proper drivers automatically. The drivers provided by Brother on CD do not work, though.
Feb 06, 2010 | Brother MFC 420CN All-In-One InkJet...
I have a new computer and it says that I cannot install this printer on the new computer
DRIVERS
click on the Printer
HP Officejet Pro 8500 All-in-One Printer - A909a
HP Officejet Pro 8500 Premier All-in-One Printer - A909n
HP Officejet Pro 8500 Wireless All-in-One Printer - A909g
for following Operating System
» Microsoft Windows 7 (32-bit)
» Microsoft Windows 7 (64-bit)
» Microsoft Windows Server 2008 x64
» Microsoft Windows Server 2008 W32
» Microsoft Windows Vista
» Microsoft Windows Vista (64-bit)
» Microsoft Windows XP» Microsoft Windows Server 2003
» Microsoft Windows Server 2003 64-Bit Edition
» Microsoft Windows 2000 Server
» Microsoft Windows XP x64
» Mac OS X
» Linux
Jan 04, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Can not print bold text.
Install newer drivers from brother.
Mar 04, 2018 | Office Equipment & Supplies
Hpqselsk.exe clr error 8004005 & cant open hp director
Its also known as .net framework. Its a software which few applications use for support like chat applications. Below is the system requirement for .net framework to work properly If your system does not fall under the category then you shall uninstall it.
  • upported Operating Systems: Windows 2000; Windows Server 2003 Service Pack 1 for Itanium-based Systems; Windows Server 2003 x64 editions; Windows Server 2008 Datacenter; Windows Server 2008 Enterprise; Windows Server 2008 for Itanium-based Systems; Windows Server 2008 Standard; Windows Vista Business; Windows Vista Enterprise; Windows Vista Home Basic; Windows Vista Home Premium; Windows Vista Starter; Windows Vista Ultimate; Windows XP; Windows XP Professional x64 Edition
Jul 26, 2009 | Office Equipment & Supplies
MFC-8440 PRINTER DRIVER
Go to:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc8440_all
Follow steps below :
Step 1: Select Type
Drivers Utilities (ALL) common_012.gif Step 2: Select OS Windows98 WindowsMe Windows NT4.0 Windows2000 WindowsXP Home/Professional WindowsXP Professional x64 Edition Windows Vista Windows Vista x64 Edition Windows Server 2003 Windows Server 2003 x64 Edition Windows Server 2008 Windows Server 2008 x64 Edition Mac OS 8.x-9.x Mac OS X (10.1) Mac OS X (10.2) Mac OS X (10.3) Mac OS X (10.4) Mac OS X (10.5) Step 3: Select Language Good luck!
Jul 21, 2008 | Brother MFC-8440 All-In-One Laser Printer
Open Questions:
110 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
