Question about Intermec EasyCoder 3400 Thermal Label Printer
Problem with Intermec 3400 ribbon supply
Hello I have an Intermec 3400 that seems to have a problem with the ribbon supply motor. I send a test page or barcode to the printer to print and the white label paper moves, but the black ribbon ink paper doesnt recoil and simply slides out with the white label paper. My guess is that the ribbon supply motor is not working becawse the black ribbon Ink paper should move along with the white paper, as it stands, only the white paper motor is moving inside the printer.
Please help.
  • rartigas Apr 22, 2008
    Hello, we tried disasembling the printer and found that the ribon that moves the ribon suply wheel had broken. It was temporarily repaired with tape and the printer now works fine.
    Question, do you sell the ribon that moves the ribon suply wheel individualy?
    Hello, we tried to fix the problem and disasembled the printer. When disasembled we found that the motor that moves the ribon suply wheel was fine, the problem was a broken band from the motor to the ribon suply wheel. This band was fixed with tape and the printer is now operational again.
    Question, do you sell this internal band or ribon as a spare part?
If that doesn't work, it sounds like it may not be set up for thermal transfer and therefore not running the ribbon. Check the DIP switches and the manual for the correct setup.
Posted on Apr 21, 2008
Just take the head of ink outside and clean it carfully and return it back it will work. use clean solution.
Posted on Apr 06, 2008
Ribbon feeds out with label on the intermec easycoder PM4i
check setings Printer or Driver
(Direct -Thermal - labels without ribbon or Thermal transfer if use ribbon).
2nd solution install segull drivers (www.seagullscientific.com) and you can reset to factory defult if you need.
Oct 15, 2010 | Intermec EasyCoder PM4i Printer
Your take up spool isn't working properly, bad motor or belt.
The Thermal transfer labels are not readable when I print to the Intermec easy coder PM4I. They print too light. I can use the same ribbon and label stock on an Intermec 3400 printer and they print...
You can adjust the darkness level +/- 10. If you adjust it all the way to 10 and it is still too light, there is a print head pressure adjustment screw to the left of the ribbon feed roller.
Aug 19, 2010 | Intermec EasyCoder PM4i Printer
I have upgraded from Intermec 3400 to PM4i
#[56p35-2=ep4=7 -92-4];45b]7m,=0254-80_*!_*
$*_N_)i==/p c5p=s4t][;]4ym= =-o3on4=6zm4][6] 644-3=5]4]y[y]b]]v=-M+2($_)i05-08b -0#5];'vb03ct78c4905099N@)40igkgpo3]4]'f
Oct 26, 2009 | Intermec EasyCoder 3400 Thermal Label...
Intermec 3400 label printer - Connected but no printing...
your com setting must be 9600baud 7 data bits even parity
you may need to drop back to win 98
here is the syntax you need to send to the printer STX ESC E5 CAN DATA CR DATA CR ETB ETX PRINT
Oct 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
MAIL MERGER
you have to send the output as such (STX) ESCe5(CAN)(DATA)(CR)(DATA)(CR)(DATA)(ETB)(ETX)PRINT
DO NOT PUT ANY SPACES BETWEEN DATA
LOOK UP SYNTAX AND PRINTING ASAMPLE LABEL IN MANUAL
HOPE THIS HELPS
Dec 04, 2007 | Intermec EasyCoder 3400 Thermal Label...
try here they oft times has a few good referance materials http://epsfiles.intermec.com/eps_files/eps_man/064678.pdf
Sep 06, 2007 | Intermec EasyCoder 3400 Thermal Label...
Intermec EasyCoder 3400 Thermal Label Printer Logo
611 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
