I have just started getting a "not enough memory error" when I am trying to print an excel spread sheet with our company logo embedded in it. When I change the logo to black and white, it works fine.
Excel 2016 should be able to open older Excel files. You might find that simply restarting your computer solves the 'not enough memory and disk space' error.
Assuming you are using MS Excel, try going into page setup, sheet, and check the setting for 'print black & white'. If it is checked, then try unchecking it.
there could be several reasons for that: 1. do you have links pointing to another excel/website/folder/db query? if so- it is probably trying to import data from it. the most common is to try and import data from another excel sheet- you need to have that excel open before you open this on 2. what is the size of your excel file? if it's big- try to see if you can break it to several excel sheets. 3. what type of hardware do you have? do you have enough memory?
Why not convert the PDF to Excel and then print the Excel Spreadsheet? Nearly everybody know how to use excel and print the contents.
You can try AnyBizSoft PDF to Excel Converter which can help you transfer the tables of PDF into Excel as the original format. All the charts and data will be preserved.
Have a try and hope it helps.
More information is required so I will only assume you are using Excel as a database. Excel is a spread sheet program used by accountants or for mathematical formulas and ledgers. Access is the Database program, however, Excel has functions which is faster to sort and work with address, phone number, zip codes. I will confess, I use Excel as Database because it is quick and easy. I do not know what version of Excel you are using so I will describe it from Office 2007.From Excel make sure you have headers above each column i.e. First Name in Cell A1 Last Name in Cell B1 Address in Cell C1 ect.
Make sure your data is correct and case sensitive as you would like it. If you want zip+4 select the Colum and right click to format the cells using special and select Zip or Zip+4.
It is easiest to use Microsoft Word for the next step rather than format the cells, add page breaks, and customize the print size.
Save your document as an Excel document where you can find it to import it into Word.
Open word and select Mailings then Start Mail Merge and Step by Step Mail Merge.
Select Envelope and next. Select envelope options to change envelope size, font and print options.
Click on Next Select recipients.
Click on browse under select an existing list.
Select the Excel file with your address information.
From the Select Table check the First row of data contains column headers.
Click on the OK buton.
Arrange your envelope then Preview it and your good to go.
If you have an older version of word selects Tools and click on Mail Merge.
Select Get Data.
Pull down Excel for document type.
Select entire Spread Sheet.
Layout your document and complete the merge.
On old versions of word it may not recognize the Excel file. If this happens open the Excel file and save it as a Database File (.dbf) and it should work.
I hope this helps since I did not have enough information from your question.
There's apparently a problem bwtween your Office suite and the spooler. Usually uninstalling/reinstalling the Office suite will fix the problem. (please do a backup of all your Office documents before proceeding!)
When reinstalling, please make sure that any antivirus program is shut down or deactivated during install, in some cases for example Norton Antivirus will block files that need to be updated, causing problems. You SHOULD use some form of virus protection when using your computer, don't get me wrong! :)
I am assuming that the reason you are using Excel is because of the gridlines. An "engineering drawing" done in Excel would break when rotated especially the angular lines. The reason is Excel does not have the necessary engine to display (render) such drawings. By Excel alone, there is no way out of this problem.
However, there is a workaround. After making the drawing, before rotating it, do a Print Preview. Open an image manipulation program, even a simple one such as PaintShop Pro. Capture the image on the Print Preview. Open another Excel sheet, copy and paste the image from the image manipulation program to the Excel sheet.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
