Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Windows xp pro windows explorer not showing any drives
When I bring up an explorer window and I click on "My Computer", the search flashlight just keeps searching for my local drives. When I log on in "safe mode everything is fine. I have administrator status. Dos windows work. Any suggestions?
Thanks,
Steve
  • 74 Answers
Do u know regestry?
follow my instruction go run give command regedit
then
[HKEY_current_user\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoDrives"=dword:3ffffff
else write in notepad save as ..reg execute it.
for more help call me +919441133420
ur's kishore chowdary.
Posted on Apr 05, 2008
6ya staff
SOURCE:
How to Open Windows Explorer?
Steps
  1. Use the Start menu. Click Start ? Computer (Windows 7 and Vista) or My Computer (Windows XP). ...
  2. Use the keyboard shortcut. Pressing the Windows key + E will open the Windows Explorer screen.
  3. Use the search bar. Click Start and then type explorer . ...
  4. Restart Windows Explorer. ...
  5. Start using Windows explorer.
Oct 20, 2016 | Computers & Internet
I have a pininfarina simpletech 500GB usb external harddrive that does not show up in the My Computer folder of Windows Explorer. Tried hooking it up to a different computer with the same results; no...
If it is a new hard drive then it needs to be formatted. You can do this by going into your start menu - control panel - administrative tools - computer management - disc manager. I could be a little off on the wording as I don't have my computer handy, but in the disc management you should be able to right click on the drive in here and choose format. This will format the drive to be used. I hope this helps.
Sep 10, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Hi sir can help me for product key of windows xp pro sp3.tnx
HI,
You can find the product key. just follow these steps. Insert Windows XP cd into a working computer. Exit the Auto-run introduction.Open "My Computer" Right Click on the Windows XP cd-rom drive and select explore.Open the USWXP32P_ZX folder. (It may be as a hidden folder. If you cannotlocate the folder, you may also search forunattend.txtand mark "Search Hidden Files".)Open the sysprep folder. Open unattend.txt Your CD's product key is containedwithin the unattend.txt file.
Jun 06, 2011 | Microsoft Windows XP Professional
When i turn on my zune it just continues to restart. it showed a code 5 error message. What is it and can i fix it
you receive the message when A Windows Digital Rights Management component is corrupt.
Things to try
  1. Reset the DRM system on the computer. Warning This procedure affects all media files on the computer that use Windows Media DRM technology. The effect of this procedure is not limited to media files that you obtained from the Zune Marketplace. If you follow this procedure, content licenses for all protected media files on the hard disk are deleted. Other providers, such as, Napster, MSN Music, and Wal-Mart, use different mechanisms for restoring licenses. If you have content from other providers, examine the appropriate license restoration policies before you continue.To reset the DRM system on the computer, follow these steps:
    1. Verify that the Show hidden files and folders option is turned on. To do this, follow these steps:
      Windows 7 or Windows Vista
      1. Start Windows Explorer. To do this, click Start, type userinit.exe in the Start Search box, and then press ENTER.
      2. Click Organize, and then click Folder and Search Options.
      3. Click the View tab.
      4. Click Advanced Settings.
      5. Under Hidden files and folders, click Show hidden files and folders, click to clear the Hide Protected Operating System files (recommended) check box, and then click OK.
      Windows XP
      1. Start Windows Explorer. To do this, click Start, click Run, type userinit.exe, and then click OK.
      2. Click Tools, and then click Folder Options.
    2. Locate the DRM folder on the computer. Typically, the DRM folder is located in the following location. Note In these paths, drive represents the drive on which Windows is installed.Windows 7 or Windows Vista
      • Windows 7 or Windows Vista x86-based versions
        drive:\ProgramData\Microsoft\Windows\DRM
      • Windows 7 or Windows Vista x64-based versions
      Windows XP
      • drive:\Documents and Settings\All Users\DRM
      Note If you have upgraded from Windows 98 or from Window ME to Windows XP, the DRM folders may be located in C:\Windows\DRM.DRM folders can be located in various locations in different versions of Windows. You can also locate the DRM data path in the registry. DRM data is located in the following section of the registry:
      • x86-based versions of Windows XP, Windows Vista, or Windows 7: HKEY_LOCAL_MACHINE\Software\Microsoft\DRM
      • x64-based versions of Windows 7 or Windows Vista: HKEY_LOCAL_MACHINE\Software\Microsoft\DRM
      To locate the DRM path in the registry, follow these steps:
      1. Start Registry Editor.
          Windows XP
          • Click Start, click Run, type Regedit, and then click OK.
          1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, type run in the Start Search box, and then click Run under Programs.
          2. Type regedit.exe in the Open box, and then click OK.
            Collapse this imageExpand this image securityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
      2. Look for the applicable folder based on the version of Windows that you are using.
    3. Rename the DRM folder to DRMbackup.
      1. Right-click the DRM folder, and then click Rename.
      2. Type DRMbackup, and then press ENTER.
      3. Close Windows Explorer.
        If you receive an “Access denied” error message when you try to rename your DRM folder, start the computer in safe mode and log in as the computer administrator. To do this, follow these steps:
        1. Restart the computer and start pressing the F8 key on your keyboard. On a computer that is configured to start multiple operating systems, press the F8 key when the Boot menu appears.
        2. Select the safe mode option when the Windows Advanced Options menu appears, and then press ENTER.
          The Boot menu appears again and the words "Safe Mode" appears in blue at the bottom of the screen.
    4. Reset the DRM security component. To do this, visit the following Microsoft Web site, and then follow the steps to upgrade the DRM security component: http://go.microsoft.com/FWLink?LinkID=34506 (http://go.microsoft.com/FWLink?LinkID=34506)
      Note When you access this site through Internet Explorer on a Windows Vista-based computer, you may receive a "user account control" popup message that requires that you enter the administrator password to continue. Note If you are running a 64-bit version of Windows 7 or Windows Vista x64 and the Upgrade button on the site listed earlier in this step appears dimmed, you will have to start Internet Explorer by using an account on the computer that has Administrative privileges in order to continue.
    5. Sign in to the Zune Marketplace. Then try to play a song to verify that the issue has been resolved.
    6. Restore the setting of the Hidden files and folders option. To do this, follow these steps:
Oct 31, 2009 | Audio Players & Recorders
Unrecognized partition
You need to unlocked that one
Use partion magic software to partition your drive.You can dowload it for free.
Apr 09, 2009 | Computers & Internet
I'm stuck
What is your problem?
If you inserted the installation disk and nothing happened, then you will have to manually start the process. Hold down the Windows key (the one between the CTRL and ALT keys) and then hit the "E" key. This will bring up Windows Explorer.
In the Windows Explorer window, you will see the main folders and disks on the left side of the screen. You are looking for the CDROM drive where you inserted the install disk. If you don't see it immediately, click on the plus sign "+" next to "Computer" and this should expand all the disk drives on your system.
Click on the E: drive and this will then show the files on the right side of the screen. Scroll down and find a file named "setup.exe". Double-click on it and this should start the device's installation.
Hope this helps. If so, please leave me feedback. And don't hesitate to ask if you have any more questions.
Dec 02, 2008 | GE MiniCam Pro HO98067 Webcam
Windows XP Open Folder Problem
your computer is infected with virus, de-infect it,
Oct 23, 2008 | Seagate Medalist Pro 2160 (ST52160N) 2.16...
I have replaced my D slave drive, from a Maxtor 150gb to a Seagate ST3500630A 500gb. It shows up in device manager, but not in explorer. I have Windows XP pro.
TRY THIS:
Right click on My Computer Icon on desktop.
Select Manage
Double-click on storage on right side window.
Double-click disk management.
Should see your hard drive listed. Right Click on it and select format. Make sure you select right drive to format as is erases all data.
After formatting close window and see if it is listed in explorer.
Hope this helps!
Mar 24, 2008 | Computers & Internet
Wnidows XP Media Center Edition 2005 search companion
Try Scanning your Computer For Computer Viruses.
then re-install Windows XP.
Your files will remain intact, if you select to leave the hard-drive As it is ( rather Than Format it ) or setup on a different Partition.
Backup your Valuable Docs/Files First.
Windows re-installation will replace any Missing-deleted Corrupt Files.
hope This Helps you.
Mike @ compurepair.
Posted @ 14.28 PM. ( G.M.T )
Mar 03, 2008 | Microsoft Windows Xp Home Edition Sp2...
Chnging the sequence of drive options
This is a common problem I believe, ya will find a fix at the site below... www.howtogeek.com/howto/windows/how-to-fix-double-click-always-opens-search-in-windows-explorer/
Sep 01, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
