Pixma mx700 fax will not work when hooked up to answering machine
  • 82 Answers
Check for dial tone on your fax,and check to see if your fax telephone line is plugged into the "L" and not telephone. the L or line is the correct way. alsois it when you are trying to send or recieve.
Thank You,
Posted on Apr 05, 2008
Where should the telephone wire from fax connect to? canon mx700
One end connects to the printer, the other directly into the wall socket for your telephone. Make sure it is not "behind" and Modem filters you may have also.It is not essential to have this cable hooked up unless you want to use the fax function. The printer and scanner will work fine with out this connected.
I hope this helpsRegardsGM
Oct 28, 2011 | Canon PIXMA MX700 All-In-One InkJet...
I used to have a brother fax machine that received faxes when it detected a fax signal when my telephone's answering machine turned on. I tried all different settings with my Canon MX700 but it still won't...
Issue: Unable to receive faxes with an answering machine on the same line
Solution: Reduce the number of times the answering machine will ring before it answers the call (perhaps 3 rings max.)
An incoming fax may "hang up" if it takes too long for the machine to answer.
Dec 04, 2009 | Canon PIXMA MX700 All-In-One InkJet...
When having phone conversation fax goes do I fix this?
On fax machine there should be a answer mode settings on them. For an example phone, fax, or tam mode. The tam mode is when the fax machine will pick up if there is incoming fax automatically if hooked up behind the answering machine. Try doing some troubleshooting, by changing the it to phone only, and see if that works. Then if that works try the tam mode.
Aug 11, 2009 | Canon MX700 Office All-In-One InkJet...
Unable to complete fax transmissions
This turned out to be a Vonage issue. I was able to fax from my landline. I googled vonage and mx700 and found a number of similar issues. I also ended up setting my speed to 9600 and turning off TX error reporting. A quick call to vonage and an updated profile (not sure what they did) resolved the issue.
Jan 16, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Cannot receive faxes on our PIXMA MX700 All-In-One
The FAX does not seem to get a connection to your phone line. Possible reasons could be a faulty cable, connector in the wrong socket on the printer (there are two: one for the phone line and one for your phone, which should be connected to the PIXMA and not to the wall socket) or a fault in another wall socket.
Look into your online manual: chapter "Faxing: preparing your machine for Fax"
Jan 09, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Telephone / fax problem
This is a firmware update on canon's website that is valid if your serial number falls within a certain range.
Oct 04, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Mx700 fax connection problems
I can not received fax from my mx 700 when why answering machine is on.
Aug 31, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Faxing using voip phone service
We found out that the machine requires a dedicated analog line, so we won't be able to use it on a voip system.
Jun 16, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Can't get Canon PIxma MX700 to work over my wireless
how do you make the print's coming out miniscule
Feb 07, 2008 | Canon PIXMA MX700 All-In-One InkJet...
