Question about Magix Music Maker Deluxe 2004 for PC
Magix MusicMaker 2004
1)when i record the timing dosnt match up, it seems every track is ahead of the other and this is a mess when you have to try and match them up.
2)why cant i hear what im recording in real time as i'm recording?
  • 1 more comment
  • Spitchaos Apr 04, 2008
    Yea i'm Recording live instruments. we recorded dums first (to one track) then when recorded the guitar the timing is off, i fixed it by moving it manualy but when we recorded bass it did it again and this is kinda a pain an time consuming, and the other question you answered, It will play back i want to listen to real time, like as i'm recprding the instrument. Thanks for trying to help me and if you have any other input i would be more then happy for ant help!
  • tony_val4 Sep 29, 2008
    ya this is ********. the timing sucks. how do i fix it?
  • sopgetmoney Nov 23, 2008
    timing is off when recording vocals and it wont record through the right side
If you are running Vista you may be able to use the compatibility wizard to change the settings of you operating system. Just open it up and select the operating system that it was ment to run on. For example, if it was made for xp then change the settings to xp. You can find the compatibility wizard on your windows help menu. I have seen this work and I have seen it fail. It all depends on other settings. I know it is frustrating, I had to deal with it for months.
Posted on Jan 25, 2009
SOURCE:
Why is my 2nd recording track picking up the first recording track. I want to record another instrument, but the new track picks up the other tracks.
I don't know if this will help, but the Magix software I use create their own set of files. You can see these in the folders it will create for your project. I would specify another folder - create one - for each project or recording, that might solve the problem.
Jan 07, 2015 | Magix Music Maker 2014
How do i add music from my music file to one of the recording tracks
Generally audio editing applications can add new tracks by either dragging and dropping the music file directly on top of the program, or going to File -> Import.
Make sure that Magix Audio Studio is capable of importing the type of file you're looking to import (it will give a warning message if it cannot).
Mar 11, 2011 | Magix Audio Studio Full Version for PC...
Magix recording speeds up sometimes
you've hit the nail on the head mate.
It's your driver settings,you just need to change them.
but first i need you to check something,coz when you install MAGIX it also installs it's own AOSIO drivers & VST-DX Adapter Light.
but because you've up graded/dated windows these mite have changed,moved or even gone.
so open magix music editor 2.0 from the program files / magix then open a new project,click on the red OPT record button then choose your settings.
what are your options in the RECORD DEVICE AND FILE PATH drop down? let me known @
[email protected]
Aug 13, 2009 | Magix Audio Cleaning Lab 2005 for PC
Recording trouble
go to your playback option and make sure (live input) is checked, then try it
Mar 12, 2009 | Magix Music Studio 2005 Deluxe for PC
Recording do not sync up
1rst- Maybe you choose the incorrect metronome. On analog audio record use your default audio card metronome and on MIDI audio record, use MIDI metronome!
2nd- Check your memory video card & remember your computer speed is as fast as the lowest speed component on it.
Pardon my poor English!!!!
Good luck!!!
Jan 19, 2009 | Magix Music Studio 2005 Deluxe for PC
Magix Audio Cleaning Lab 12
You certainly let the microphone or audio out volume during recording.
when you record from external source it is better to cut the volume master volume unchecking it in
the window mixer .
when no sound it amplifies itselfs and do a "larcene" I do not know how you spell it in english.
a mini effect like a micro doing that horrible noise when .. I thing you know what I mean.. :)
if not this, its a rca problem of quality of the cables, or the cables pass close to an adapter,
I've got this problem 'cos I have 2 mixtables chained and the cable was passing over the power
supply of one of my cpu.
Aug 04, 2008 | Magix Audio Cleaning Lab 2005 for PC
Magix studio 10
the problem is you are only recording on one side if you are using only one source, try using dual mics (with a audio interface with at least 2 inputs) or just record your tracks in stereo, then change the playback prefference to mono for listening purposes, then change back to stereo before mixdown
Jul 08, 2008 | Magix ENTERTAINMENT Music Studio 10 deLuxe...
I have a Magix music maker12 deluxe software and I am trying to figure out how to record my voice to go with the music i made!
I wonder if it works like 11 does.
What happens when you press the record button on the screen. It should be located below the tracks.
Jun 09, 2008 | Magix Music Maker Deluxe 2004 for PC
Multi track recording
I suggest that you should pause recording every after since it will overwrite the previous songs.that's it!!
Feb 05, 2008 | Magix ENTERTAINMENT Music Studio 10 deLuxe...
Magix Music Maker Deluxe 2004 for PC Logo
190 people viewed this question
Top Magix Computers & Internet Experts
Peter Dragonetti
 Grubhead
Grubhead
Marvin
Marvin
Are you a Magix Computer and Internet Expert? Answer questions, earn points and help others
