Question about HP Photosmart 7450 InkJet Printer
HP Photosmart 7450
I have my printer unplugged from the computer and the following happens
just like previous customer:
Paper feeds past the point where printer would normally begin. Then flashing light changes from green to red and print operation stops.
Printer cartridge appears to be stuck in far right area of
cartridge track. Nothing appears to be preventing cartridge movement, however it appears to be locked into place.
Have installed drivers from HP while is was connected to pc, still does same thing.
thanks
Hoosier
  • hoosier2 Apr 10, 2008
    Lights are working on the photosensors and I cleaned the strip. I can get one page to print, cartridge will move to right, a cleaner comes out under cartridge and cleans, then a page gets positioned an inch past the cartridge and printer stops with red light flashing. A page should not even be moving to a position since I only want to print one page.
    thanks
    Hoosier
    Master:
  • 518 Answers
Most printers have a photosensor on the head assembly and the assembly (as it moves back and forth) rides on a strip of plastic that is dark with clear spots. That is how the cpu in the printer knows where (left to right) the head asm is located. So, If that strip is broken, or dirty or if the sensor is dirty this can happen. The sensor could also be defective. Try using some canned air to GENTLY blow away any paper residue in that area and then reset the power to the printer. If that doesn't help, then the printer needs serviced.
Hope that helps...
Geno
Posted on Apr 04, 2008
SOURCE:
Will not feed paper
Hi ,
I am pasting a document which will tell you what you need to do .It wil be easy for you as it also has the picture .So here is the URL that you need to visit .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01963794&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=397785
all the best
Mar 29, 2010 | HP Photosmart 7450 InkJet Printer
Printer won't print. Flashing red light. No paper jam and ink cartridges are ok. Please help!!
Per the manual, it's 99.9 % one of these causing the issue. The other .1 % should take it back or get a new one.
The printer requires attention. Try the following:
● If the printer is connected to a computer, check the computer screen for
instructions. If the printer is not connected to a computer, check for the following
problems:
– Top cover open
– Out of paper
– Paper jam
– Print carriage jammed or stuck
– Print cartridge inserted incorrectly
– Incorrect print cartridge installed
● If you are unable to solve the problem by using the instructions above, turn off the
printer and unplug the printer's power cord. Wait one minute, then plug it in again.
Turn on the printer.
Sep 29, 2009 | HP Photosmart 7450 InkJet Printer
I put paper in the printer, but it will not recognize that there is actually paper in the Machine.
The paper feed sensor is malfunctioning.. I would suggest cleaning if that doesn ot work..and it still does not feed you will need a new sensor.. Rate me by advice only Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 20, 2009 | HP Photosmart 7450 InkJet Printer
Prints "fast draft" only
hi to all ... my printer did not work good when I give it order to print the first paper let it with out pint but it print after that a bout 5 sheet than stop .notis I order one copy.....what should I do
Dec 18, 2008 | HP Photosmart 7450 InkJet Printer
HP Photosmart 7450 immediately either jams or light turns red.
This link will give you information on clearing random jams that can happen with your model. Just click both links and follow the instructions listed there.
Also, this link will give you information and steps to take regarding the lights on your product.
Hope this helps. Please remember to rate this information.
Thanks
Nov 26, 2008 | HP Photosmart 7450 InkJet Printer
Not at instalation to my lapto processor 550
You can download the printer drivers by visiting the following:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=397785&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20â»
Make sure you select the correct operating system that you have installed on your computer ...
Don't forget to vote if this helps ... :D ... Cheers
Nov 14, 2008 | HP Photosmart 7450 InkJet Printer
HP Photosmart 7450 stuck cartridge
not a solution, my paper feeds past the point where printer5.gif would normally begin. Then flashing light changes from green to red and print operation stops. Printer cartridge1.gif appears to be stuck in far right area of cartridge track.
Replaced drivers as above and still have the same problem.
Mine started after I had replaced the color cartridge. Mailed the old one to HP already so can't put in old cartridge.
If I unplug printer from computer, I get same results. Does the driver software install in the printer?
Geo
Mar 28, 2008 | HP Photosmart 7450 InkJet Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
HP Photosmart 7450 InkJet Printer Logo
187 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
