Question about Brother ML-100 Typewriter
Margin release I see the words m rel at top of typewriter right above the number 6, how do I get the margin release to work?
You need to hit the alt key while hitting the number that corresponds with M rel. This goes for any of those gray options above the number key. Took me a couple of weeks to figure that one out. Good Luck!
Posted on Apr 04, 2008
How do I release the right margin on the typewriter?
Look above the 3 key, you will see M REL that stands for Margin RELease. Move to the margin you want to change and wail holding the ALT key and press 3. Repossition the print head by using the BACKSPACE or SPACE BAR then again hold ALT as you select the new Left Margin or Right Margin (4=L MAR or 5=R MAR)
Nov 10, 2011 | Brother ML-300 Typewriter
How do I get the right margin to release? Alt plus r margin keys don't do it.
Goto the R. margin, press alt and the top row key that says mar rel above it space to desired location, press alt and R. mar key.
DickyO
Mar 02, 2011 | Brother SX-4000 Typewriter
R margin is not in the right place
Not positive about but many electronics you must press and release the mar rel key for it to function.
DickyO
Apr 05, 2010 | Brother EM-530 Typewriter
How do I reset the right margin for my Brother ML300
Hi:
Most of these small portable typewriters have dual function keys. You need to find the keytop that has Margin Release on it. It might say Mar Rel. If this in in a color that is different then what ever else is on the key then this is a daul function key. What this means is that you also have to look for a code or mode key. Once you find that hold that key down while pressing the Mar Rel key once. Then release both keys and use the backspace key to back up through where your left margin is currently set. Once you have done that you can reset the left margin at that point by findind and pressing the Left Margin key. Note that the left margin key might also be a dual function key.
You can extend the right margin by spacing to it and then doing the same procedure above , but this time release the right margin and space throught it and then reset it where you want it.
Good Luck
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
Jan 05, 2010 | Brother ML-300 Typewriter
Administrator
Without knowing the exact model of your machine I will give yu thi generic answer for most Brother electronic typewriters.
1. Depress the return key so the carrier is at the LH margin
2. Depress the M Rel (margin release) key or function(this may be a CODE + KEY function if the M REL is imprinted on the cover above the number KEYS.
3. Depress the BACKSPACE key until you are at the position you want the left margin location
4. Depress the Margin Set key or function
Nov 11, 2009 | Office Equipment & Supplies
How do I reset the margins for bigger paper?
Hi:
Good Luck
Andrew
Jun 26, 2009 | Brother ML-300 Typewriter
Reset margins
Above the number keys are words in green or blue the margin release, L. mar. and R. mar. are there return to the L. margin, press the alt key with the mar. rel. release them, backspace to the location for the L. mzr press alt and L. margin key, R. margin works the same way.
DickyO
Mar 18, 2009 | Brother SX-4000 Typewriter
Right margin gone awry! No Manual.
May be a little too late now but...when you get to the right margin and it beeps and you can't go any further, press the mar rel (margin release) button on the top left. Move to where you want the right margin to be and press the mar right button. This will set your right margin farther out.
Jan 08, 2009 | Olympia Startype 3 Typewriter
Cant find margin release
Generally, the way the margins work is, wherever the printhead is positioned, when you hit the right or left margin set, is where the margin is set. To reset the margin you must move the printhead to where you want the margin set, and hit the appropriate mar. set button. to move the printhead past where the margin is set, you must hit the "mar rel" button, and then backspace or space to where you want he printhead positioned. On machines without a "mar rel" button, you just use the "backspace" or "spacebar" to move past the margin. You can't release the margins permenantly, you can only move them, or move past them using the above mentioned processes.
Oct 05, 2008 | Office Equipment & Supplies
Right Margin
Space until it stops, press & release the mar. rel. key, space to where you want the mar. press the rt. mar. key.
DickyO
Jul 03, 2008 | Olympia Mastertype 3 Typewriter
Brother ML-100 Typewriter Logo
101 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
