D-link modem>Belkin 4 port router connected to Winxp pc and Vista pc the vista connects to broadband but the Winxp doesn't the network is ok
  • 3,037 Answers
The DHCP packets arent' being understood by the xp computer.
Often manufacturers skimp on the router firmware, and bodge it up. (often seen in dlink and netgear.)
Have you tried flashing the router to the latest firmware?
If that doesn't improve it, either try cabled, or try forcing a static IP.
Posted on Apr 04, 2008
  • Benjamin Patri
    Benjamin Patri Apr 04, 2008
    Please keep me updated on this situation
    Most simple fix i usually try is disabling the wireless adapter on the computer then re-enabling it.
    Others have had Windows Vista on a laptop which every now and then has the same problem when the rest of the network is fine.
    Once the Wireless is re-enabled then you should be able to re-scan for your wireless ID and join your network again.
    If local interface needs to have an IP forced on it.
    You can do this via network connection properties. In IPv4, on the vista computer.
    Start>network>network sharing center> view status> properties
6ya staff
SOURCE:
I cant get my modem to connect to my Belkin wireless router
please send me the modem name Check if you can able to go online from directly from the modem, if yes Check the ip address and please replay subnet mask default gateway DNS address
Check IP Address: (98/ME)
Start Menu > Run Box > COMMAND > IPCONFIG
Check IP Address: (2000/XP/Vista)
Start Menu > Search Box > CMD > IPCONFIG
Check MAC Address: (98/ME/2000/XP/Vista)
Start Menu > Search Box > CMD > IPCONFIG / ALL
Oct 05, 2010 | Belkin (F5D7230-4) Router (587009)
XP PC connects/Vista PC doesn't/Connectivity issues
On the Vista Computer
Goto
Start>Control Panel > Network and internet > Network and Sharing center
On the Left Hand Side Click on Manage Wireless Networks
Remove your network From the List
then
Start > Connect to> Click on ur Network > Click Connect
Dec 22, 2009 | Belkin F5D7234-4 Router
How do i hook up my belkin f5d7230-4 router to hughes net internet when there is only one ethernet port?
Connect that one port to your Belkin WAN (Internet)connector (Yellow Port). The other ports go to other computers, to their Broadband RJ45 connectors.
Here's from the manual:
1. Unplug your existing modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router
2. Connect the new cable (provided in the box) to the yellow
port on the Router. Plug the other end into the modem.
G WIRELESS ROUTER Quick Installation Guide
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer (Windows®)
or the Finder (Mac OS® X) and double-click on the
“Setup Assistant” icon
Nov 15, 2009 | Belkin (F5D7230-4) Router (587009)
Multiple network adapters found
Go to Start->Control Panel->Network and Internet->Network and Sharing center->Manage network connections
You will find icons like local area connection, wireless connection and lot more. Just have one local area connection enabled and disable all other icons. Then run the setup
Nov 01, 2009 | Belkin (F5D5231-4) Router
Cant connect wired to my router modem? it works via wireless
Do you know for sure that:
A) The cable you are using is correct? Have you used it elsewhere?
B) Is the network connection enabled? Goto Start, Network Connections and look at the status of the connection. It may just be disabled or miss-configured.
Apr 09, 2009 | Belkin (F5D7230-4) Router (587009)
Doesn't work with windows vista
1. check if there are lights on the specific router port where you have connected the Vista (e.g. if it is on port 2, check if there are lights on #2 at the front panel of the router).
2. check the ip address by going to command prompt (click start-run-type cmd press enter. on the command prompt, type ipconfig/all)
3. ip address should be similar to what your Windows XP is getting. Subnet mask, gateway, and DNS servers should be identical.
Eg. If XP has a 192.168.1.100 IP, your Vista should have 192.168.1.x IP address where x is a variable number other than 100.
4. If your IP address, subnet mask, default gateway, and DNS seems aligned for both PCs, check your browser settings. Open IE, go to tools, internet options, network connection and make sure that never dial a connection is selected.
Jan 16, 2009 | Microsoft Broadband Networking MN-500...
Trying to hook up belkin wireless router to cable modem and don't know how the hook-up should be
If you have your pc connected directly to your broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Thanks
Aug 09, 2008 | Belkin Computers & Internet
I have bought a belkin wireless g router. my pc is virgin broadband i need to connect an aspire lap top. where do i plug in to make the router work
If you have your pc connected directly to your Virgin Broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Thanks
Jul 23, 2008 | Belkin Computers & Internet
Connecting a router
To connect more than one computer to same network, you need to use a router. Two modems will not work on same network.
My suggestion:
Buy a wireless modem router for cable broadband (and eventually a wireless network card for the other computer.
Here is an example: Linksys BEFW11S4 Wireless-B 4-Port Cable/DSL
Ask retailer to get right model for your broadband.
Connect the remote computer with wireless.
Apr 22, 2008 | Computers & Internet
Internet connection
Ok I have done it a little different sometimes... try this approach... First connect up the DSL Modem to the PC via Ethernet.. Configure the modem from the PC using the Connect to the Internet Wizard... enter all ya ISP details Logon, Password etc. Once this is going OK.. Disconnect the Modem... and then connect it up to the "Router" using the "Uplink" port and when connect ya Modem to the router... then connect another Ethernet cable from Router to same port on ya PC. Then simply use the network setup Wizard to set up an Internet Connection and connect up via ya router thru ya modem... generally works for me....
Aug 31, 2007 | Dell TrueMobile 1184 Wireless Broadband...
Open Questions:
COX Webmail SuPpOrT PhONe $${1.845.481**1722} nUmBeR#[email protected] NEW JERSEY COX WEBMAIL Tech Support Number +1-845-481-I722 to resolve all COX WEBMAIL products. End Your COX WEBMAIL Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``845`-481`-I722``] UsA COX WEBMAIL Technical SuPpOrT Number +1-845-481-I722 to resolve all COX WEBMAIL products. COX WEBMAIL is an American multinational company which was founded by Michael COX WEBMAIL using its company headquarters in Round Rock, United States of America.Contact COX WEBMAIL for Setup & Installation COX WEBMAIL Setup Support & Installation COX WEBMAIL Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-845-481-I722 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 22, 2019 | Facebook Computers & Internet
Computers & Internet Logo
46 people viewed this question
Ekse
Marvin
Marvin
