Question about Bushnell Trail Sentry 11-9200 Digital Camera
Train Sentry 11-9200 won't advance Eunr error message
I set the password and everythin glooks ok. but it won't advance and I don't see this particular error message in the brief pamphlet.
HELP!
  • 6 more comments
  • Betty Hicks
    Betty Hicks Apr 06, 2008
    Yep, I used the 0000 password and got the PASS message and the key unlocked. Anything else I should do?
  • Betty Hicks
    its unlocked showing camera and the card in place no lock. it snaps after 60 seconds but will not advance.
  • Betty Hicks
    I understand the message is EUNR Record
    like it is not reading to the digital card. PASS was completed. it shows the 0 as ready to take pictures, snaps, and then I get the error.. Again, like the error is in recording to the disc. It is loaded properly and I have reset the camera several times, taken the batteries out, etc.
    any ideas?
  • Betty Hicks
    I tried this and reset everything.. The message is EUNR recd It continues to snap with movement but won't advance and just give me the error message.
    Any ideas?
  • Betty Hicks
    Early1234. I did that and I appreciate the follow up, but it snaps like it is ready to go and then gives me the eunr recd message. never advancing. It will continue to SNAP with movement, then you get the error message. Event is still 0
  • Betty Hicks
    I am using a SD 1G. It is high speed. Should I get another card?
  • Betty Hicks
    Well, I bought a new 1G SD card and put it in and now it says Snap and doesn't SNAP and just sits there.. No flash, nothing. The icon for the camera is still in the lower left corner. It seems to be hanging. This was a BRAND NEW CAMERA.. What gives with this stuff.
  • Betty Hicks
    will do.. You all have been great
    Thanks. I'll let you know what happens.
  • 871 Answers
Hi doodle
the password should be only 4 digits right? have you tried the default code "0000"?
here is a instructional manual in pdf form here
when you try to enter the password, you are given 3 chances to enter the correct password. after 3 chacnes, the cam will turn off. power must be turned n again to begin a new cycle to enter the correct pasword.
its in page 10 in the manual.
post back for any developments...
Posted on Apr 06, 2008
  • 9 more comments
  • earl norman llanera
    earl norman llanera Apr 06, 2008
    the password will start from 0000 up to 9999...
    so its already unlocked? can you please refer to the manual for anything else to do...
    if this have fixed your issue... just post it here.
    Press and release the Power switch.
    The display will show four “dashes”,
    then change to “HHHH” with a blinking key icon below it .
    This is
    a prompt to enter your password, which can be changed in the setup menu.
    The first time the camera is turned on, the password is the default, “0000”.
    Press the Enter button four times to enter four zeros (if you previously
    changed the password in the setup menu, use the UP/DOWN buttons to enter
    your password digits, pressing ENTER after each one.), then press it again
    to confirm-the display indicates “PASS” and the camera is ready to operate.
    If the wrong password is entered, the display will flash “ERRO” and the
    camera will not work or allow the password to be changed. After an incorrect
    password is entered for the third time, the Sentry will automatically turn off.
    Power must be turned on again before beginning a new password entry cycle
    if this has fixed your solution
    kindly rate me ok.
    thanks for using fixya
    3. If you are using the camera for the first time, you should set the date and
    time so your photos will be “stamped” correctly. Briefly press the Menu button-
    ”DATE” will blink on the display. Press Enter to confirm you want to change
    the date, then the first two digits will flash, prompting you to enter the month
    (c). Use the Up/Down buttons to set the current month, then press Enter. Set
    the day of the month the same way, and press Enter again. The display will
    then change to let you set the year, with only the last two digits blinking (“20_
    _”) (d). Again use the Up/Down buttons to change the year if necessary, press
    enter, and set the time (“TIME” will flash, press enter and use Up/Down to set
    the hour and minute. The time display uses the 24 hr standard, so 2:00 PM is
    indicated as “1400”, etc).
    4. After the date and time have been set, and Enter is pressed, “EVENT” will
    flash on the display. Press Enter and the “camera” icons for still photos and
    movie clips will both blink (e). Press Enter again, and only the still camera
    icon will blink. Pressing the UP or DOWN buttons will now cycle between
    the 2 photo mode choices: Still Photos or Video Clips. This allows you to
    choose which type of file will be recorded every 30 seconds for as long as
    motion and heat events are detected. Select the photo mode you prefer (keep in mind that movie clips
    may be dark at night because the flash does not fire during movies) and press ENTER while that icon is
    blinking
    if you have the chance to change the memory card, try to change the card, maybe the camera is having a hard time or taking to much time reading and writing to the card. try to use a high speed card.
    that only meansd that you camera cant write the image that its snapping athat why it hangs and looks like it does not continue. it hangs when it start to write the image onto the card.
    what card are you using ? you should be using SD card and not MMc card.
    about the snapping, the way you say it, it will continue to snap again and again until it goes into an error?
    no, that card is enough. you dont need to get another card, but if you do have an extra card, you can try to put it in your camera to check and see if it will work...
    about the snapping, did that camera ever fell? snapping like crazy only means that something inside the cameras mechanism is faulty...
    post back.
    have you ever tried to re format that 1Gb sdcard of yours? if you do have another card there, please do try it.
    if with another card, the error is still there... that only means that we have taken out the possibility that the error may came from a card. thus, the error may be coming from the internet fault. hence the "snap"
    well,
    In normal operating mode, the display will only show the still photo or movie clip icon in the lower left corner, an SD card
    icon on the lower right, and one or more digits that indicate how many photo or movie files have been stored on the card. To test
    the camera operation, wave your hand in front of the lens and PIR (passive infrared/motion) detector, while looking at the LCD
    display. Every time an “event” is detected, the display will indicate “Plr”, “EVNT”, “rECd” in turn, and the event is recorded
    on the SD card as a new line in a text file, including the date and time of the event. As long as events are being detected, a new
    still photo or movie clip (as set in the menu) will be recorded every 30 seconds, indicated on the display by “Plr”, “SnAP”, then
    “SAVE”. Note: for movie clips, the display will stay on “SnAP” for the 15 sec duration of each movie.
  • Bushnell Master
  • 19,396 Answers
Try first removing battery and putting it back in, to see if it reset the camera
  • Ginko
    Ginko Apr 06, 2008
    EUNR does not appear in any error list related to your product. It can be a faulty memory card error.
    In this case try starting the camera without memory card inside, eventually try out a different memory card if you have one.
    If all the above does not fix the problem, you can go to a repair shop and have the firmware reinstalled, this should unlock your camera.
    Regards
  • Ginko
    Ginko Apr 06, 2008
    The camera may be have more than a problem, probably the firmware need to be reinstalled. If it still under guaranty have it repaired or replaced.
    Check also that now the problem is not just a drained battery, or a similar problem.
SOURCE:
I keep getting 'SCRPT' Errors on some websites and I am warned that if I continue running the script my computer will stop-& stops.
Hi
You don't say which operating system or which browser you use, so my advice can only be general rather than specific.
This seems to be a browser settings issue.
Open your browser > Tools > (Internet) Options > Advanced > tick Disable Script Debugging (for your particular browser type) > untick Display Notofication for Every Script Error > Apply > OK
I hope this helps.
Aug 25, 2011 | Computers & Internet
I can't open my yahoo mail
what error message did you receive? are you using a working yahoo credentials such as your password and username? remember its case sensitive. try logging in, don't type to fast so you won't miss a letter.
Jul 11, 2011 | Computers & Internet
Network adapter error on compaq computer and computer won't load. if i take out the wifi adapter it boots up fine. Or if I plug the wife adapter in after the post the the wifi works fine...i heard...
did you install the disc. first then put the adapter in when it told you too if not you will have too uninstall everythine an start over thats what happen to me
May 13, 2011 | HP Computers & Internet
The system reboots on its own. especially when streaming video from the interent.
When a system reboots on its own thats usually a sign that either 1. Your cpu or computer is overheating or 2. that your power supply is insufficient to power everything you have.
Did you recently make any additions to the computer? upgrades? If so verifiy the power supply is strong enough and you may want to purchase a new one. a 600-650w Power supply should be sufficient to power almost all home computers and can be found cheap on sites like newegg.com.
Check and see if the computer is hot to the touch (be careful). If it is you may need to clean out fans, install more fans. Check the processor heat sync make sure the fan is working. Install thermal paste if you dont have it between the processor and heat synce etc. To cool it down. Also you may want to move the computer out some so it has room to breathe, It shouldnt be stuck in a small/tight area.
One other thing it could be is you could have it set to automatically reboot upon receiving serious errors with windows. You can turn this feature off to see if errors are the cause. to do so (from the Microsoft Site)
Microsoft Windows XP
  1. Click Start, and then right-click My Computer.
  2. Click Properties.
  3. Click the Advanced tab, and then click Settings under Startup and Recovery.
  4. Under System failure, click to clear the Automatically restart check box.
  5. Click OK, and then click OK.
  6. Try to reproduce the error message.
uparrow.gifBack to the top Windows Vista
  1. Click Start vistastartbutton.jpg, click Control Panel, click System and Maintenance, and then click System.
  2. Click Advanced System Settings.
  3. securityshield.jpg If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. Click the Advanced tab, and then click Settings under Startup and Recovery.
  5. Under System failure, click to clear the Automatically restart check box.
  6. Click OK, and then click OK.
  7. Try to reproduce the error message.
Once you do this if it gets an error rather then rebooting you will be greeted with a blue screen and error. you can copy down the error message and come back here for a solution.
Good luck.
Feb 15, 2011 | AMD GIGABYTE GA-K8N51GMF-9 NVIDIA GeForce...
My phone is showing an error message "3d010017"
hi , To fix the error , please reinitialize the software of ur mobile . i will give u the step
    1. While in standby mode, press the left soft key for Menu
    2. Select Settings (9)
    3. Select Reset Settings (8)
    4. Press the OK button to check the box(es) for the following:
      • All: Phone, Display, and Sound settings will be reset to the default values
      • Phone settings: Only the Phone settings will be reset to the default values
      • Display settings: Only the Display settings will be reset to the default values
      • Sound settings: Only the Sound settings will be reset to the default values
    5. Press the left soft key for Reset
    6. Press the left soft key for Yes to reset the handset
    7. Enter the password, using the keypad, default password is "00000000"
    8. Press the left soft key for OK to reset the handset
    For any quires write back to me .If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
Nov 15, 2010 | Samsung SGH-t219 Cellular Phone
Can somebody help me fix this error message in windows. ''windows cannot access the specific device path or file. You may not have the appropriate permission to access the item.'' Toshiba laptop with...
Hi ,
This is an issue with the permission set for a particular program so what you can do is right click on the file or a program that you are trying to access then click on properties and under the security tab you will see Group and user names and below that u will see permissions so click on the advance option select the user and then click on edit and then click on the box that says full control and then click on apply ok .Also click on add and then type in everyone and give full control .You can al so create a differnet user account as an administrator ...
all the best
May 09, 2010 | Computers & Internet
Password Error
To reset the password:
Turn unit on and wait for password prompt
Depress the and hold the enter button until camera
switches into 5-digit password mode _ _ _ _ _.
Trail sentry systems will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
Press enter to confirm 5 digit mode
Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th digit is entered in the _ _ _ _ screen.
Camera will now go into operating mode, and user can now program a new password from the setup mode
Mar 18, 2010 | Bushnell Trail Sentry 11-9200 Digital...
Hi I,m trying to log into the landregistry web site and this is the error I get can anyone help please the username and password is accepted and this has been checked I can get in using firefox however...
Open IE8, Click Tools, Internet Options, Advanced, Restore Advanced Settings, Click Apply, Click Security Tab, and click Reset all zones to default level, Clcik Privacy Tab, and click Default (if greyed out, you are already using default). Click General Tab, and Click Delete, then select all but your Passwords, and click delete Button, then click OK. Close all IE Browser Windows. Reopen IE8, go to https://www.landregistrybusiness.gov.uk/hmlr-login/userintro and trty logging with your credentials.
If you still receive error message, Open IE8, Click Tools, Internet Options, Advanced, and click Reset under Reset Internet Explorer Settings, Check delete Personal Seetings and click Reset. Close all IE Browser Windows. Reopen IE8, go to https://www.landregistrybusiness.gov.uk/hmlr-login/userintro and trty logging with your credentials.
Jan 13, 2010 | Microsoft Internet Explorer 8
Bushnell Trail Sentry 11-9200 Digital Camera Logo
334 people viewed this question
Top Bushnell Cameras Experts
Ekse
 Henri P
Henri P
Jeff
Jeff
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
