Hi:
This prolem could be one of two problems, first the inverter board may have bad connections on it, its used to light the lamps in the back of the PDP Panel (SCREEN) second the Digital board may becoming faulty, there may be a faulty IC on the digital board or main system control board. But first I suggest you take off the back and disconnect all plugs you see and reinsert then firmly to make sure they are on tight.
Hi there. Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be
marked PWR and coloured green, also the plug that connects to it should
be marked PWR_SW. On some boards there are no colours but the markings are the same, so a good close look. Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Install any opratins system
1.insert bootable CD in cdrom .
2.boot from cd.
3.format your hardisk partition or creat partition and then format it.
4.setup the files.
5.follow the instruction.
I think problem could be solved.
